Our latest Turbo F-Body accessory
Old Oct 25, 2011 | 09:54 AM
ModularTurbo's Avatar
Default Our latest Turbo F-Body accessory
Check out our latest Turbo F-body accessory
The CBR power steering line kit.
Our line kit has many awesome features including:
-Moves lines out of the way if running our front mount kit or your own DIY truck manifold kit. (also accomodates the "EBAY" kit)
-Stainless Steel braided, crimped, and fully assembled.
-High pressure power steering specific design.
-Bolt on with nothing required for install other than basic hand tools.
-Cleans up the engine compartment.
-Easier then making your own.
-It cost the same as buying the parts separtely from Summit or Jegs, and making it yourself.
Order Here:
Power Steering line kit order link
Old Oct 25, 2011 | 10:02 AM
tomz28's Avatar
looks good i need new lines too
Old Oct 25, 2011 | 10:16 AM
In stock and ready when you are!
Old Oct 25, 2011 | 10:31 AM
Avengeance's Avatar
I wonder if this could be routed around and used with my F1C.... Id like to replace my lines and remove the stock cooler.
Old Oct 25, 2011 | 10:42 AM
Buy it, try it, and if it works post up pics.
I'll then give you a discount on future products for being a guinea pig for us.
Old Oct 25, 2011 | 10:48 AM
Avengeance's Avatar
Well... since you're gonna twist my arm.
Ill send you a PM.
Old Oct 25, 2011 | 12:26 PM
Need_a_Camaro's Avatar
Definitely a sweet kit, too bad I'm broke from fixing stuff I didnt break. I'll hit you guys up when I replenish the play fund. One question though, would you be able to replace the upper section of rubber hose with braided? I use up and fwd headers, and that hose is pretty fkn close to my collector. I may pull mine off and see if -6 fits on the nipple from the resevoir. Thanks for building a sweet kit guys, keep up the good work. If only we had a sweet aluminum pulley, and a nice fabricated resevoir.....
gi8e7oi825's Avatar
I love it! I don't have FI yet, but I'm going to have to pick it up for Christmas just 'cause it's pretty and my alternator doesn't like getting leaked on.
Old Oct 25, 2011 | 12:34 PM
Just an afterthought, could the nipple be cut off the resevoir and replaced with a bulkhead?
Old Oct 25, 2011 | 02:01 PM
When you are ready for FI call me we have many different kits available, from mild to wild.
ALL of our turbo systems do not require standing up the radiator or butchering the car.
Old Oct 25, 2011 | 02:03 PM
You can modify our kit any way you want to.
Also, I'm sure a little metallic insulation wrap will prevent the heat from hurting any NON SS braided tubing.
And, we have a power steering pump relocation bracket kit that includes this line kit coming VERY SOON....
thanks
Rob
Old Oct 25, 2011 | 05:18 PM
boss79z's Avatar
Will be buying one at the first of the month
Old Oct 25, 2011 | 05:55 PM
The section of rubber is push lock hose 9-1/4" long.
We chose to stop the braided return hose at that point
so guys wanting to keep there P/S cooler could do so.
If you want to keep your cooler just cut the stock rubber return line off
the metal tubing coming out of the steering rack and hook it to the
hose bard crimped into our braided hose.
Old Oct 25, 2011 | 07:46 PM
2000RATA's Avatar
Sent you a PM.
Old Oct 30, 2011 | 09:57 AM
It's looking like this may be useful to Procharger guys too!
