Gm high-tech supercharger wastegate what do you think
I just the GM high-tech january issue with the article about wastegates on 5th gen disc kits. Ati always has kept me away from this approach. Any thoughts? Blow off and waste gate?
UNDER PRESSURE MOD
I read the article as well, and don't really see the benefit. Essentially you're setting the pulley ratio so that you hit max rpm for the blower, but you blow off any additional boost generated above a certain threshold. I have always been under the impression that max torque is what kills motors, not neccesarily horsepower past that rpm. So if you pulley the setup to make 550 rwtq max, but then limit the boost after that point all you're doing is losing horsepower.
I don't know, maybe I'm way off.
I was about to post on this after reading it and think it is a great idea. A centrifugal blower is limited on the low end so that it wont over boost at higher rpms. By using a wastegate you can use a smaller pulley to have your target boost hit earlier in the rpm range. I have always preferred turbos because of the simplicity to adjust boost pressure based on what octane you run. With this kind of setup you potentially could run a 17-20 psi pulley and control it with the wastegate to take it down to 8-11 psi at 91 octane and when you use race gas raise the boost pressure for the track.
