Question about keeping A/C.
Old Oct 31, 2011 | 12:07 PM
703 CAMAROSS's Avatar
Default Question about keeping A/C.
My question is why dosent anyone just move the compressor? There must be a reason behind it because it seems like it would be so simple but yet no one moves it. Has anyone tried it before?
Old Oct 31, 2011 | 12:14 PM
Trl_ws6's Avatar
It's not just a simple as moving the compressor. The majority do front mounts which usually requires standing the radiator up and moving it further up within the core support thus causing your condenser to be further up too. Majority also use a fmic and it starts to be an extremely tight fit that lacks the air needed for cooling.
Old Oct 31, 2011 | 12:23 PM
I understand that part but why dosent anyone move the compressor instead of plumbing the pipeing around it? Then you could make a truck manifold kit work right?
Old Oct 31, 2011 | 12:46 PM
ABeasst's Avatar
Where are you going to move the compressor to is the real issue. When you start sticking all the turbo equipment into the engine bay there isn't room to move it.
Old Oct 31, 2011 | 12:48 PM
evo462's Avatar
It is possible to keep the compressor in the stock location, you just need an LS2 Corvette exhaust manifold on the passenger side and a BMR turbo K member. Look at my build thread for pics.
There will probably be some other options for keeping the AC from vendors available soon as well. The C6/truck manifold setup is fairly expensive to do by the time you factor in the k member and everything else required.
Old Oct 31, 2011 | 01:00 PM
Do you have a link evo? Idk how to find it lol. And im sure there would be a place to mount it. Maybe you could mount it to the passanger side and drill a whole in the wheel well and mount it there? Im not around my car to look now.
Old Oct 31, 2011 | 03:15 PM
StrokerLS1's Avatar
From some of the research that I have done it looks like this kit will allow you to keep A/C and run a factory K-member. Some people on here have used it. I dont know about keeping the radiator in the stock position though. I am looking at possibly buying this kit.
Old Oct 31, 2011 | 03:40 PM
ABeasst's Avatar
I did my kit with twin C6 manifolds and left everything in the stock location. Its doable without a doubt. See my link.
http://s179.photobucket.com/albums/w...0Twin%20setup/
Old Oct 31, 2011 | 07:35 PM
ModularTurbo's Avatar
We sell a "keep the A/C kit". We mount the turbo where the alternator goes. This also keep the radiator and fans stock too.
Old Oct 31, 2011 | 08:53 PM
I'm trying to fit a 91mm turbo lol
Old Oct 31, 2011 | 10:01 PM
Oh, well... we can do that too.
Call me
Old Oct 31, 2011 | 11:45 PM
stangtrader's Avatar
So said kit is like the Turbo tech street kit?
As far as moving the pump not enough options. You could do a log on the drivers side or something similar to the ptk kit
