F1a or F1c
With that said... since it flows more... the F1C should theoretically produce more power per PSI with all things the same.
FWIW... Im putting together a 370cui and decided on the F1C... never even considered the F1A.
It's not like you can only run an F-1A from a certain cube range and then you have to move up. Two of us just now told you that the differences between the two are not vast, so the cubic inches really do not matter. Cubic inches are for giving the motor more power to spin the bigger heavier F series blowers.
The F-1A and the F-1C are the same damn size and step up ratio, the volute size is slightly larger on the F-1C but that has nothing to do with the cubic inches.
Not hard to get man...
I went with the F1C because I REALLY wanted the F1R but from what Ive heard the characteristics of the F1R are very peaky power.... so I opted for the F1C because I will be doing some street driving. My motor is only a 370cui but we did go with the AFR 230 heads so I figured I have the heads to flow it... why not go with the the blower that can more efficiently put it through the motor AND meet characteristics that meet my needs.
If its the last blower youll buy... Id go F1C. Why not?
Put it perfectly. Btw, just noticed your from Norcal. Where at? I moved from San Jose, CA about 10 months ago, can't wait to get back next year. I also knew Rick lol, I was going to buy his old black Trans Am from him early last year but decided against it for other reasons.OP, what kind of power are you looking to make? Tell us that and what engine you have, and then we can give you better suggestions from there.
Rick is a good guy and a personal friend of mine... he actually built my new motor, spec'd the cam, and will be building my exhaust then doing all my tuning. My car should be down in his shop within the next couple weeks.
He is a good guy, I kick myself from time to time for not buying that Trans Am, you ever see it? I test drove it and even with the half assed 20 minute tune he did it still had noticeable pick up. For that compliment, you owe me a ride in it when I go back home and you finish it
Also, F-1C on a 600 ci setup? Efficient? Lies.
Don't listen to me guys, I worked like 16 hours straight and need to get my happy *** to bed lol
