RMCR High Mount YSI Set Up
Old Mar 6, 2012 | 10:17 AM
  #81
MikeRMCR's Avatar
Sounds Awesome!!
The car looks great. What size pipe are you running of the blower for the inlet. Even with 4" pipe we have seen 100rwhp gains by just running a filter of the back of the supercharger.
Old Mar 6, 2012 | 04:40 PM
  #82
ivan c's Avatar
Originally Posted by MikeRMCR
Sounds Awesome!!
That is a 4'' pipe, I ordered vfn ram air hood today that should closed I hope
Awesome set up Mike thanks
Old Mar 6, 2012 | 04:42 PM
  #83
ivan c's Avatar
I will post video of dyno run this soon
Old Mar 6, 2012 | 04:44 PM
  #84
ivan c's Avatar
Originally Posted by phatasp
Sounds bada$$ Ivan, sure makes me want to upgrade my t-trim. Almost warm enough to see what it will do.
Thanks, what kind of power are you making with your t-trim and what boost ?
Old Mar 6, 2012 | 07:02 PM
  #85
98BLOWNZ28's Avatar
Car looks good Ivan! Did you remove your drivers side hood strut to clear the filter? I've been trying to find a way to run a bigger filter off the blower, but it's not that easy with the space we have to work with.
Old Mar 6, 2012 | 07:09 PM
  #86
ivan c's Avatar
No, my blower hits the ram air part of my hood
I have WS6 ram air hood on my car, I think this VFN hood will work.
I have to wait 5 weeks to get it
Old Mar 6, 2012 | 08:01 PM
  #87
phatasp's Avatar
Almost 560rwhp and 580 lbs torque. at 15 lbs boost The tuner said it was pulling timing bad, due to the iat,s. So this winter I put a meth kit and a way better exhaust on. Tomorrow (hopefully) I,m taking it to get retuned.
Old Mar 8, 2012 | 04:38 PM
  #88
Rybar's Avatar
Ivan just sent me this video, it's about to go on the Dyno today:
FYI Ivan's Trans Am was originally an LT1 car. So he has the 93-97 style WS6 Ram Air hood. He's also recently converted it to Auto from T56 and reworked the front bumper/rad support for a proper front mount intercooler.
http://youtu.be/9izeOZo2yeQ
Old Apr 7, 2012 | 05:04 PM
  #89
ivan c's Avatar
Default Dyno Results
Finally some dyno results, all was good car made 656rwhp / 632trq that was 15psi, 16deg of timing, 94 octane at 6200rpm through TH400.
I had wheel slip at about 5500rpm, we will try again in couple weeks with some weight in the trunk and less air pressure
http://www.youtube.com/watch?v=0UpYpQsRoLk
http://www.youtube.com/watch?v=LpcPLuroANQ
