Stick with LS3 shortblock or go iron?
but im sure you will put it down either way turbo or nitrous..and btw i have stock casting ls3 heads milled .020" on my friends vette and we have seen about 900rwhp at 5k rpms with no signs of pushing water..once i change out his valvesprings I am goin for for over 1000hp once everything is ironed out and thats on e85
That's crazy about Modular turbo. Best of luck.
As far as a fuel system. Check out something from Lonnie's.
Use a good in-tank pump,Y'd into a big external pump(Magnafuel, Fuel Lab etc) on a hobbs switch, -10 feed and return and ID2000's. Will support a whole bunch of power on E.
I'm doing that set up on my similar on my Z0.
Also some of us run the aem truboost or a gm boost noid and mbc to have a high/low setting.
