Stick with LS3 shortblock or go iron?
Old Nov 11, 2011 | 08:41 AM
Stangkilr's Avatar
Default Stick with LS3 shortblock or go iron?
Im switching over to a turbo from nitrous. I have a Schwanke forged 376ci LS3 in the car right now with -2cc relief pistons, good rods and stock crank. Im kind of new to this turbo stuff and have NO idea where to start. I only have a goal. Thats to have around 1000whp and runlow 9's/high 8's. I already have a good chassis, trans, rear end so its just the fuel system and engine/turbo setup im up in the air on. Any idea's on who makes a good hot side setup? What fuel setup to run ect...Thanks in advance
Old Nov 11, 2011 | 09:25 AM
venom ws7's Avatar
Check Josh at KYTP builds awesome stuff
For fuel system check nasty and keep the LS3 but unless you're planning to run race gas
All the time then You need to lower the comp for 8:5 - 9:5 range
For 1000rwhp with your trans/rear and 376-390ci GT4788 will be perfect for street and 8sec passes
Like I said Josh
Old Nov 11, 2011 | 09:40 AM
chris@hps's Avatar
Call josh@ Kentucky Turbo for the kit. You are also going to have to get new dish pistons(blower/turbo) as well. I would also pin the main caps and or get billet main caps. All ARP Hardware,Turbo Spec Camshaft. A torque Converter designed for a turbo setup as well.
Chris
Stangkilr's Avatar
Thanks I will give them a call. Problem is I know he takes a while on his builds. Which I can understand, im just trying to get this done before TX2K12.
Old Nov 11, 2011 | 09:43 AM
Stangkilr's Avatar
Chris
Already have the billet main caps and all ARP studs/bolts. I will have Allan Futral spec me out a turbo cam. I am going to run E85 for fuel. Tq converter I already have planned
Old Nov 11, 2011 | 09:58 AM
98Z28CobraKiller's Avatar
Restricted User
I'd keep the LS3 and another nod for Josh. When is TX2K12?
Old Nov 11, 2011 | 10:43 AM
Stangkilr's Avatar
March 16th-18th
Old Nov 11, 2011 | 11:16 AM
87silverbullet's Avatar
Getin touch with Rob at Modular turbo then. I'm sure Chris could get it done before then
Old Nov 11, 2011 | 12:03 PM
chris@hps's Avatar
You will need to change out the pistons as well. You will need to get the compression down.
Chris
Old Nov 11, 2011 | 12:30 PM
PRAY HRD's Avatar
what's your current cr with what cc chamber heads?
Old Nov 11, 2011 | 01:43 PM
Stangkilr's Avatar
11:1 with 70cc L92's. I am changing the heads out for 317's though.
Old Nov 11, 2011 | 01:50 PM
venom ws7's Avatar
Why change the heads? and yes I forgot about Rob at Modular turbo I believe they have hot side for single turbo setup.
Old Nov 11, 2011 | 01:59 PM
Stangkilr's Avatar
Heard the L92's have thin decks. I dont want to have issues with them. Correct me if im wrong.
Old Nov 11, 2011 | 02:22 PM
ls1curt's Avatar
aluminum block will be fine for your setup and just build your own hotside . Your goals should be very easily to accomplish, esp running e85
Old Nov 11, 2011 | 02:28 PM
Restricted User
In all reality, that only gives you about a month and a half to get a turbo kit fabbed up as you will realistically need two and half months to iron out the bugs, figure out the setup and get a max effort pass off without blowing **** up.
venom ws7's Avatar
You're right about that but I'm not sure if the 317 heads are much thicker than the L92 I'd like to know too hopefully someone will get us more info..
I'm saving up for AFR 230 IMO the best 4bolts heads available for boost
Old Nov 11, 2011 | 02:34 PM
chris@hps's Avatar
L92's and 317's have about the same deck thickness. You are going to need a set of aftermarket heads to get a good thick deck on them. If not you will be lifting heads and pushing water. TFS,AFR, Mast Heads are what you should be looking at for deck thickness for the power you are wanting to achieve without issues.
Chris
Old Nov 11, 2011 | 02:35 PM
Yes they do, but cjg454 on here made damn near 1000 rwhp with them and he was using e85. He had more cubes with them though. I think the cooling effect of e85 helps keep l92 heads down and not lift them. If you want to keep your intake and so forth, just use a set of the new PRC ls3 aftermarket casting heads which have a thicker deck and a 6 bolt option.
Old Nov 11, 2011 | 02:45 PM
Stangkilr's Avatar
I want to switch over to a super victor. They dont make one for L92's and id rather just throw the 317's on it so I dont have to worry. I can sell my L92's pretty easily.
Old Nov 11, 2011 | 03:20 PM
Stangkilr's Avatar
Well Modular Turbo is out of the question. If you dont buy a turbo from him he wont sell you a kit. What he told me on the phone. Im about to just throw nitrous back on the car. Screw this bullshit.
