Widening ring gaps???
Old Dec 12, 2013 | 09:23 PM
  #61
mrstepheneades's Avatar
Originally Posted by The Alchemist
So what causes #7 to go boom on a stock ls1 shortblock that was tune to 10.5:1 afr, 13 degrees of timing, no KR and 14psi of boost at 6500rpm?
I'm basically same tune. 10.8-11.2 afrs and 14 degrees timing. On 20psi and no issues yet knock on wood. Pump 93/ dual 10gph methanol using 100% meth. Stock ls1 all but cam. No special bolts either. I have all steam ports hooked up just like factory.
