600 hp on stock 5.3?
What cam and intake would be best for the job?
I will drive it on e85 and rev about 7000rpm, please help me what more parts I need, This will be a budget build.
Later I will build a forged engine but I want to play earlier
Will it be better to get a 6.0 lq4 to build then the 5.3 lm7 I got now?
Ls6 cam
Stock truck intake
Stock heads
Fmic
76+ mm turbo
Truck manifolds
And plan for $1000 worth of software and tuning time by someone who know what they r doing.
http://www.hotrod.com/techarticles/h...g_bang_theory/
So that should answer your question.
Now my only question is why 5.3? I mean can't this be down with a 5.7L? Maybe someone can chim in that knows why???
put some decent heads on it. a nice cam. some patriot valve springs, head and main studs and let it eat. I want to put 118 back in my tank and see what it'll take to destroy this 5.3 but I've been having too much fun on pump gas and 10 pounds to wanna find out
oh, and I believe a 5.3 is the same block as far as dimensions as a 5.7, you can bore it out to a 3.900 and make a 5.7 out of a 5.3
Except the last line if you know someone that can rewrite your PCM with their tune for free or cheap. This recipe is pretty simple and common.
2 in tank pumps is what alot of guys run. Even the factory fuel rails r good for that power if I remember correctly.
And read the STICKY ab the "real cost of forced induction" at the the top of the forum...
Also, if you read the stickies at the top of the page, they will answer a ton of your questions and anything else you can find in many threads already posted plus some. There are a ton of other threads just like yours with great info already. Good luck.
The turboconversion will not be possible to get legal. I will need to remove all the turbo stuff once in a year.
http://www.jegs.com/p/Patriot-Perfor...22045/10002/-1
But I donīt realy know if I have 16.505" Spring Bases or 16.565" ?
And then run it with an ls6 cam?
