Wastegate ?'s..Can U manually open valve?
44mm wastegate
11lb spring
I tryed to manually push valve openby pushing it with soft end of small deadblow hammer. I put a lil effort into it but doesnt seem to crack open?
Should I be able to maually open valve?
FYI... i did this being curious on how stiff a 11lb. spring is. This seems to be way to hard for air pressure to open.
11lb spring
44mm wastegate
11lb spring
11lb spring
10 Psi spring will be very hard to manually open. Best way to check the gate is to hook up an air compressor with a gauge and regulator then turn up the regulator and see at what Psi the gate starts to crack open and also what psi its fully open.
If you put the end of your dead blow on the valve and then put the gate on the floor, you can push it open. It will still take quite a bit of effort.
I put an 8psi spring in my gate and I can barely open it with both thumbs. This is normal.
But yes, the compressor and regulator method is the proper way to check the spring pressure. Cracking pressure should be roughly half of full open pressure.
He is using the dead blow to push with.
The spring is hard to move.
If you do the math for the area of the diaphragm and the force being applied
vs air PSI the valve should open at or near the boost rating.
44mm wastegate
11lb spring
11lb spring
