can i pull a 02 sensor to check back pressure
Old Nov 21, 2011 | 09:06 PM
bad6as's Avatar
Default can i pull a 02 sensor to check back pressure
ok flame on.
i want to check my back pressure, can i just pull a 02 sensor out and install my gauge in to that? when the car goes wot the 02 get ignored any ways right?
Old Nov 21, 2011 | 09:21 PM
tomz28's Avatar
Yup is this on the mustang in your sig?
SPRAYED 01's Avatar
My tuner at speed inc did. So id say ya go for it. And yes at wot your stock 02s are not sending anything back to the pcm.
Old Nov 21, 2011 | 09:23 PM
Fbodyjunkie06's Avatar
Sounds like a novel idea no flame suit needed
Old Nov 21, 2011 | 09:26 PM
bad6as's Avatar
yeah car in sig, im trying to figure out if im making the horsepower i was told the turbo can support. i was told it only needed 20psi to make my goal. after some track time i have fallen short of said goal. gonna throw it on a dyno again now that the converter is with in check, and see what power its really putting down. i want to keep an eye on the back pressure too.
it made six and a half to the wheels on 14psi threw a loose converter. im looking for 900-1000 under full boost if the back pressure dosent go too high
Old Nov 21, 2011 | 09:31 PM
What brand converter and stall speed? What rear gear and tire size
Old Nov 21, 2011 | 09:33 PM
bad6as's Avatar
ptc converter, i dont know the stall speed, 275/60/15 drag radial, 3.27 gears
Old Nov 21, 2011 | 09:36 PM
Cam72aro's Avatar
Thats where a back pressure tester goes. I have used them several times at the dealerships.
Old Nov 22, 2011 | 10:52 AM
stevieturbo's Avatar
Originally Posted by bad6as
ok flame on.
Depends where you want to measure it, but it is a fairly normal approach. Just use some metal tubing for a few feet to dissipate any heat before you put the rubber gauge hose on
Are you trying to find pre turbo, or post turbo ?
Old Nov 22, 2011 | 11:07 AM
bad6as's Avatar
I want to compare the amount of boost the engine, to the pressure in the merge pipe.
