Stick with LS1 or go LQ4?
My plan initially was to buy a junk yard LQ4 with higher mileage and toss some rod bolts in it and let it eat. Since the LS1 block and crank are in pretty good shape I was kicking around the idea of getting some forged rods and pistons for it and running it. Just looking for some opinions on what you all would do.
My plans are a budget build for either motor.
-On3 76mm .96AR turbo
-TU1 Cam
-Dual valve springs
-Truck manifolds
-2.5" Spoolin hotside kit that I am getting from a buddy
-Ebay intercooler
-Tial wastegate
-BOV? not sure which one
This car will see the track a couple times of year and get driven a lot on the street. I don't really have any HP goals but would like it to make north of 550 at the tires.
I know if I forge the LS1 and get all new bearings and clean it up I will have more piece of mind knowing it should take a beating. If I go the LQ4 route I would be nervous on running a higer mileage motor without touching the bottom end. One of the local JY's has a LQ4 from a van with 75k miles on it and they want $950 for it which doesn't seem like too bad of a deal. If for some reason that fell through would it be a terrible idea to look for a 100+k mileage motor and run that?
Am I correct in assuming if I go stock bottom end LQ4 it will be cheaper up front compared to prepping my current block and forging it? If I kept the LS1 I would have to buy truck manifolds and would want some 317's to go on top and the LQ4 would already come with these.
Again, just looking for some opinions.
Thanks for any help and suggestions.
As far as a BOV i would look into the RPS if on a budget... Rob from modular turbo sells them and they are 100$....
Oh and the heads, If you go with the LS1 and forge it you'll be able to lower the compression via piston dish so you could use you stock ls1 heads for now and get a better head later if you wanted.
My budget is not HUGE, however if it takes me a little longer to save up and do things right then that is what I will do. If I did go with an LQ4 now and ran it stock for a year without it blowing, then I would more than likely pull it again next winter and forge it.
Of course the other big ticket items (drivetrain) will need their attention as well.
Bottom line, I would go with the LQ motor.
Do you know what the mileage on their LQ motors was 87silverbullet? What mileage is on some of you other guys' JY LQ4 pullouts?
Thanks.
If I were going to forge an engine, I would not do it to the aluminum one over the Iron one.
