should i go vortech v9 or turbo
Its in his. And another reason i didnt kno what setup to go with is because they shut gateway down so i cant get any track times so that leaves me to the streets lol.
well since no one has really put any actual info to answer your question I figured I would help you a little. I used to have a v9 on a stock bottom ls1 with full bolts ons. It made 500rwhp. It is unlikely that you would be able to get 600rwhp with it. If you found one for $2500 that is not a bad price. yes you can probably fab a turbo kit cheaper, but it will be alot more work. The vortech kit is bolt-on and retune, the only major work is drilling the oil pan for the oil feed line. With a big enough turbo you can make 600wheel pretty easy. I like my v9 though it just wasnt fast enough.
