is 11.1 comp to much
Old Nov 27, 2011 | 08:47 PM
Ls_Nova's Avatar
Default is 11.1 comp to much
So is it...building a nitrous motor and really want to throw a single turbo on it...compression is about 11.1 may be able to drop down to 10.5 10.1... Is it possible if I run e85.
Old Nov 28, 2011 | 01:27 AM
Nitroused383's Avatar
It's not too much if you know what you're doing. Cake walk with e85.
Old Nov 28, 2011 | 02:24 AM
Ls_Nova's Avatar
Nice to hear I just may have to do it...
Old Nov 28, 2011 | 08:52 PM
Ls_Nova's Avatar
No one else..
Old Nov 28, 2011 | 08:57 PM
Ryans99ls1's Avatar
Like was said above, if you have the fuel to support it, do it. 11:1 will make for a very fun street car. Its going to spool very fast and shouldnt lack power anywhere.
Old Nov 29, 2011 | 03:16 AM
caddy03pimpin's Avatar
I'm running 11.1 on a blower with 10lbs of boost I'll tell you it's very responsive
Old Nov 29, 2011 | 05:31 AM
I run 11:1 compression with a very high DCR cam (8.8:1). I put 5k miles on my 130,000 mile stock bottom end ls1 mostly on 8lbs of boost with 92 pump gas and 100% meth injection from a 15gph nozzle. I have made a few passes on 11-12lbs of boost and even one on 15-16 lbs of boost with a little avgas. Keep your timing conservative and your octane up.
Almost forgot to mention Intake air temps are critical. My IAT's are always 5-15 degrees below ambient air temp with the meth so this really helps. You start blowing hot air (150+ degrees) and parts won't last long.
Old Nov 29, 2011 | 01:12 PM
Ls_Nova's Avatar
Thanks for the info I will keep in touch with you when I get close to completion..so would I be better off running e85 or we also have a 100 octane pump..or I can simply run 110 octane it been this will be a weekin car..what would be best choice..
Old Nov 29, 2011 | 04:31 PM
If you have the fuel system and availability I think e85 is a no brainer.
Old Nov 29, 2011 | 04:51 PM
Ls_Nova's Avatar
Thanks...
