can I push it even further!!??
520rwhp stock bottom LS1 (with ARP rod bolts)
P1SC @ 6 psi 6 rib setup twin intercooled
AEM water/meth injection 50/50 mixture
previous owner says cam is a B1 Comp cam 221/221 558/558 114LSA
stock 853 heads with ( or so i was told)comp cam 918 titanium springs
Z06 pushrods
Ls6 intake & 80mm BBK TB
headers and blah blah and alot of other small stuff
My questions are will a set of stock 317 heads (reusing the springs and pushrods) work along with raising the boost to around 10 Psi (have'nt decided if to do it with the P1 or go D1). Also, is the cam specs ideal for my setup or no?..car is my DD but has ran as fast as 11.3 at the track ..have'nt ran it yet since i put in the Moser 12 with 3.90 gears. thanks for any help
Blowers raise compression. Why lower compression so you can make more boost to make up for the lost power?
I'm not BSing you. Nowadays it's common for us to run 10lbs on 11-1 compression centrifical cars with no failures. Just make sure you have a good fuel system.
Your stock heads dont 'suck' that bad...look into a good blower cam and keep the stock heads in place.
Brutespeed.com
Brutespeed.com
do a quick search, there are alot of ppl who run it. Try giving bob a call on monday and talk to him. Hes a good guy to work with and he'll set ya straight.
198/197 .478/.478 115LSA
is stock cam specs on ur yea LS1.
Anything in the low 230's duration is considered a mild cam. Overlap...ive heard it both ways. ive heard alot of overlap will cause you to lose boost, but, they were talking like a 109lsa.... most boost cams are in the 114-117 LSA. so even that 220 cam is still small. i DD my car in the summer and i dont have any driveability problems. and most will say that i have an nonboost friendly cam, but it works well so far for me. My blower, cam, and gears, all shine at 3k and up, so 3k up pulls are ridiculous lol. Dont get caught up in cam stuff. Get bobs cam and call it a day. and your right, you dont need high lift cam like mine to make power.
