BMW e46 swapped Ls 370ci 4L80 BEP 91mm (UPDATED 6-5-12)
Show of hands for all that saw "328ci" and started thinking "all that money in a custom crank when he could've just built a 408 & gone faster..."
You may consider trying some flipped LS3 camaro manifolds (~$50 + shipping on various gen 5 camaro forums) to clear that steering shaft. You'll likely have to geat creative with the FEAD unless You point them upwards.
Regards,
Kurt
Regards,
Kurt
and i think the 5gen manis pretty much look the same at the on the last cylinder
Love the swap... Really thinking of part out my s10 and swapping my LS1 in one of these so i can get girls to come in my car (in central jersey if you don't have bmw, benz or lexus, your nothing).
lol yea where I live if you have a car your consider cool..lol but the rears I think are ok...but time well see....it sucks they dont have lsd in the rears other then the M3 and a M3 rear is like 1500 used lol Ill straight axle it before I buy one of those...just gonna weld the rear up to spin both tires...
After doing some research and a help from a friend (speedracer5532) I decided to install on a 110 to help start the valve events sooner to help spool the turbo...the turbo hasnt been picked out yet but its gonna be 91-101mm...or whatever I can get for a decent price in that size range.
#33
I'll be curious to see how it works out. I was looking at the epp cam to use a turbo cam in a 370 turbo motor bc i really like having a cam with some lope. good luck with the build.
#34
The cam worked good in my last build and I built chevyboy82188's ls1 383 turbo kit with a s480 turbo (1.32t6 96mm wheel) and the brute speed blower cam and his spools 1 psi 2500 and full spooled by 3k (10psi) and its installed straight up. I figure since I have a smaller cubed motor and gonna have a bigger turbo imma need all the help I can get...
#36
