Best Forced Induction Piston?
Old Dec 7, 2011 | 08:55 AM
mr_biscuitz's Avatar
Default Best Forced Induction Piston?
Wondering what all the upper hp guys are running and why? Well anything above 1000rwhp. Been using Diamond custom non coated and the gapless top ring and been reading a bunch about people not liking Diamond. Gets me thinking.
Old Dec 7, 2011 | 09:02 AM
Nowhereman's Avatar
Gotta be KB slugs.
Their Hypertectic aluminum allows real close piston to wall clearances.
Lots an lots of AA F/Cs have run em for years.
Old Dec 7, 2011 | 01:05 PM
killernoodle's Avatar
Whats wrong with Diamond? Where did you read this?
Hypereutectic pistons are more brittle than forged pistons and therefore more likely to snap a ring land. They might be ok for stock replacements, but for a turbo car you probably want the forged piston.
Old Dec 7, 2011 | 02:02 PM
westtexasbuff's Avatar
Wiseco!
Old Dec 7, 2011 | 02:21 PM
SS4Matt's Avatar
I have a nice set of coated Diamonds. I've cracked a block and the diamond piston that came out of that hole was completely fine, I threw it right in the next motor with no issues. They can take a LOT of abuse.
Old Dec 7, 2011 | 03:15 PM
Its mainly just preference like everything else when building an engine but the design of the piston and the top ring depth. The two sets I used last year were .260 and they offer a .300 but curious as to what other people are using. Wiseco seems to be a choice that others like but Ive personally never used them.
Old Dec 7, 2011 | 03:39 PM
Nowhereman's Avatar
KB make both cast and forged pistons.
Old Dec 7, 2011 | 03:47 PM
HydroStream6's Avatar
Diamond here for years with no issue. Never tried a Wiseco in an LS motor but have had some bad luck with them in other motors. Other people here swear by Wiseco. There really is no best piston. Buy a good name at a good price and be done with it.
Old Dec 7, 2011 | 06:33 PM
Wish it was that simple and not asking for the omg the best piston out there, just wanting to know what others are using and having good success with. This year Ive spent 2k on pistons and wanting to know before I buy another set if I should go a different route or stay with the same Ive been using.
Old Dec 7, 2011 | 06:40 PM
98Z28CobraKiller's Avatar
Restricted User
Why?
Old Dec 7, 2011 | 06:56 PM
lmt0705's Avatar
Had wiscos in my 408 and had major galling at the bottom of the skirt using there reccomended .0045 clearance. I'm trying coated diamonds this time and they reccomend .007 clearance! I ran them in a different build and they worked flawlessly..007 is a little scary though!
Old Dec 7, 2011 | 07:14 PM
Restricted User
Your problem is the stroke, not the piston.
Old Dec 7, 2011 | 07:23 PM
lmt0705's Avatar
That's what I've been told, however this seemed excessive. Should have just left it together and I never would have known
Old Dec 7, 2011 | 08:07 PM
jpracing01's Avatar
Cp pistons gets my vote
Old Dec 7, 2011 | 08:58 PM
SATAN's Avatar
Actually, Wiseco's have a bad rap for galling on the skirts. It is not the pistons fault though. It is the manufacturer's recommendations fault. They say to have a piston to wall clearance smaller than is actually needed. At least this is well documented in the import world. I don't know about the bigger bore engines.
Old Dec 7, 2011 | 09:16 PM
2000RATA's Avatar
There is no contest. CP is the leader in piston technology period. JE would be 2nd in this list yet still 1st rate. And JE makes a line of pistons called SRP (cheaper/budget). I would put Diamond on par with the SRP line.
Old Dec 7, 2011 | 09:56 PM
The first go around was due to going lean, ran out of pump. Took out one side so just started new and then that time it was too rich, took out another 5 so going to start over again. Its been a nightmare the past two years, the thing runs damn good if we can keep it together. 2 blown headgaskets, and then the two different times with the pistons which I didnt reuse any bearings or rings, started fresh I dont tune my car myself and the tune wasnt aggressive either. Im in the market again and just wanting to basically buy the best option that I can afford. Its not going to fix any other problems but figured why not ask what others are using......
Old Dec 7, 2011 | 11:25 PM
+1, you are pulling the bottom of the skirt of the piston out of the cylinder on a 4" crank. You aren't doing that on a 3.622 crank. That is where your wear is coming from.
Old Dec 8, 2011 | 01:55 AM
lmt0705's Avatar
I know the stroked thing is an issue as it is well documented, but it seemed excessive for the amount of use the engine had
Old Dec 8, 2011 | 02:52 AM
skinnies's Avatar
Get a new tuner!
