Will this combo make decent power ?
Old Dec 9, 2011 | 03:05 PM
spd500's Avatar
I am putting together a 5.3 with a stock lower end and have already bought a few parts for it , now I am thinking I want to add a turbo to the project . I have a stock 5.3 motor complete , a carb intake , a MSD 6010 , a Comp xer287hr cam , and a set of 241 heads that have been ported . I am looking at adding a turbo and using the 241 heads and the Comp cam , I have been told I need a 70-76mm turbo for the 5.3 . I found this one on Ebay fairly cheap -
www.NOT-A-SPONSOR.com.org.gov.net.edu
Will this combo work , or do I need to do something different ?
Oh yeah , on pump gas and without a intercooler ?
Old Dec 9, 2011 | 06:16 PM
HydroStream6's Avatar
For $500 you can do better. That's only a P trim unit. Small turbine. I'd look into a used Precision 76 or a Turbonetics 76. It will cost a touch more but will have a larger turbine. Plus the peace of mind of a name brand turbo.
If you're stuck at $500, pick up a MasterPower turbo.
Old Dec 9, 2011 | 07:12 PM
spd500's Avatar
Ok , I will check into that , thanks . If anyone knows of a good deal on a used turbo , I would be interested . But , I would still like to know if this is a decent combo ? Should I get rid of the cam and get something turbo specific ?
Old Dec 9, 2011 | 08:11 PM
What are the specs on that cam? And what fuel do you plan on running?
Old Dec 10, 2011 | 09:29 AM
spd500's Avatar
Here is a link to the cam specs - http://www.compcams.com/Company/CC/c...csid=1094&sb=0
I am hoping to run pump gas in it , and will be keeping the boost moderate .
Old Dec 10, 2011 | 09:58 AM
That cam really isn't ideal. You'd gain some driveability by switching to something a little more tame, and may even gain power. The LSA on that cam is a bit low for boosted applications.
Old Dec 10, 2011 | 01:17 PM
allout06's Avatar
i have a torquer V3, and im on a 111lsa with a procharger....mine drives fine and my tuner didnt see any evidence of leaking boost... take it as u will
Old Dec 10, 2011 | 01:44 PM
LS1NOVA's Avatar
The real deal Precision 76 will prob cost you a little over 1000 for a used one. If you want to spend 400-700 look into a Master Power 70mm with a .96ar or a Turbonetics TC76 or TC78. They will get you into the 600rwhp range.
Old Feb 25, 2020 | 03:33 PM
Mavn's Avatar
"I MAID THEESE"
VS Racing Billet 7875 . .. 600 wheel with ease on ethanol.
That cam is massive for a 4.8 … lol
Old Feb 25, 2020 | 05:09 PM
ddnspider's Avatar
Shame on you MAVN for bumping a 2011 thread!
