stock fuel rails
Old Dec 23, 2011 | 11:44 PM
4doortypels's Avatar
Default stock fuel rails
anyone know the limits on how much fuel they can supply??? ls2 rail...
Old Dec 24, 2011 | 01:32 AM
skinnies's Avatar
Ls1 rails we have dyno proven 855rwhp on e85, on another car made probably around 925 to 950 on e85 but never got it on the dyno.
Old Dec 24, 2011 | 08:23 AM
LS1NOVA's Avatar
Im assuming these are the return style Skinnies?
Old Dec 24, 2011 | 09:36 AM
SPRAYED 01's Avatar
Rails are cheap, why not replace them?
Old Dec 24, 2011 | 10:13 AM
LS1NOVA's Avatar
Why spend money if you dont have to?
Old Dec 24, 2011 | 10:53 AM
skinnies's Avatar
They ARE NOT the early year ones with the return on them. They are 2000 rails with a 6an adapter fitting on them, about a foot of 6an hose to the regulator. From the pumps to regulator is 8an on my car, 6an return. We run them at 95lbs pressure in boost since we are running 80lb injectors.
Everybody who claims you need rails at lower power hasn't done it, we've done this on several cars making north of 800 without a problem on e85 which requires a lot more fuel than pump/race gas.
Old Dec 26, 2011 | 11:59 PM
i agree why spend money if you dont need to, i got rid of professional products aftermarket rails. i would like to keep the engine beauty cover on my car, as it has been professional painted the way i wanted it. the cover has plastic clips that clip on the the rail... so aftermarket rails may cause me to lose it. im will be running a rectangle cnc ported ls3 heads forged iron 408 with a tc 78 turbo. going for 15 to 20 psi, looking for 700-800 rwhp. id like to keep the factory rail if at all possible. will be running QT premium 93 octane. no e-85 as there are only 3 local stations with in a 50 mile radius.
Old Dec 27, 2011 | 05:11 AM
LS1NOVA's Avatar
Your going to want a bigger turbo (or Dr Turbo's new bigger AR upgrade)
Old Dec 27, 2011 | 12:06 PM
js2fst's Avatar
Qt gas here no way! Not in my cars or lawn mower or anything. Qt diesel ok.
Old Jan 2, 2012 | 12:14 AM
Originally Posted by LS1NOVA
Your going to want a bigger turbo (or Dr Turbo's new 1.15 AR upgrade)
hoping for a 1.32 need some room to breath
Old Jan 2, 2012 | 08:07 AM
9sectruck's Avatar
how and the hell did a fuel rail question turn into how big of a turbo thread.
Im also looking for the hp rating for ls2 rails. wiil they support 1300fwh
Old Jan 2, 2012 | 08:13 AM
LS1NOVA's Avatar
excuse me internet cop for giving some friendly advice.
Old Jan 2, 2012 | 08:28 AM
koolrayz's Avatar
As skinnie said the rails will support a lot of powwer.
The biggest issue is the stock regulator position IMHO
On my ls1 i removed the dampner on the center of the rail and made a new piece that fits there with the snap ring, that had a female npt. I ran it to the fenderwell and mounted my regulator there. you also have to rework the "T" at the back of the car where it fed the stock regulator. I then used the vent line for the new return.
