would like imput on turbo and waste gate size
Old 01-05-2012, 01:31 PM
97_C5's Avatar
Default would like imput on turbo and waste gate size
Ok so putting a 370 together, forged pistons and rods stock crank. Will be running either tea's ported tfs "turbo" heads or stage 3 prc 317 casting. Will have a cam custom ground. Questions are will a b&g s475 be a good choice for a turbo, and what size wastegate should I run? Will be on a truck manifold setup if that makes any difference.
Old 01-05-2012, 01:56 PM
WheelsUp84z's Avatar
no smaller than a 44mm, but the bigger the better it will be able to control the boost. the JGS 50mm would be a good choice
Old 01-05-2012, 02:12 PM
97_C5's Avatar
Ok, will i be able to get buy with a manual boost controller? And what spring size do i need not understanding that??? New to all the turbo stuff
Old 01-05-2012, 10:12 PM
ModularTurbo's Avatar
How much HP do you wanna make???
Old 01-05-2012, 10:55 PM
97_C5's Avatar
Well would like to be in high 6xx area, car will mainly be on the strip so want something that likes upper rpm range.
Old 01-05-2012, 10:58 PM
97_C5's Avatar
Also why do most of the bigger waste gates not specify what springs they come with?
Old 01-06-2012, 06:16 PM
TC78 + JGS 40mm = proven 650rwhp on an LS with quick spool up
Old 01-06-2012, 08:10 PM
97_C5's Avatar
Pm'd you
Quick Reply: would like imput on turbo and waste gate size
