Gt4788
408 iron and 317s, pump gas, no meth, 13* IIRC he made 800/800 on 14/15 psi-
race gas and 20 psi, same timing, made 900.
If he adds timing and a bit more boost, itll make 1000 no problem.
Do a search, and it should give you a good idea.
It doesnt seem to light until 3800-4200, so keep that in mind. Its like a smaller 67mm on a supra, takes a bit to get lit, then its full steam.
Louis
Louis
For some reason I think I should go bigger and then tinkerd told me he has a .96
So I have no clue I'm flip a coin and see what happens
.96- Tight A/R turbine housing, in relation to singles. Will spool quickly, but top end power will suffer.
1.08, 30-40 hp difference, with little laggier boost ramp, carries top end a little further.
1.36 Noticeable difference in both spool and power production at high RPM. turbine flows much better than .96, however, due to this, we lose the ability to light it at low rpm.
Yeah the housing can be changed, that's the good part!
I'm thinking about going in-between the .96 and the 1.36 and see what happens!
