AN lines for radiator hoses
Old Jan 10, 2012 | 12:42 AM
minytrker's Avatar
Default AN lines for radiator hoses
What size do you need to run on a track only car? I have found -16AN fittings is that correct size?
Old Jan 10, 2012 | 08:00 AM
trans2000am's Avatar
stock water pump you will need -20 look to spend 500 bucks for everything that was about what i spent, not that many companys make -20 either which sucks
Old Jan 10, 2012 | 11:32 AM
minytrker's Avatar
I have an electric race pump. I found -16an fittings for it but not -20.
Old Jan 10, 2012 | 11:44 AM
crashinaz's Avatar
Check your local hydraulic shop (Parker Store, etc)... -20 in a JIC 37 fitting. They make JIC 37s up to like -34... If you're looking for aluminum, dunno.
Old Jan 10, 2012 | 02:09 PM
tim99ws6's Avatar
we ran dual -12 on our last setup. Personally, I didnt think it was enough for a street driver, but making a drive in it, the temps did stay around 200 with a Griffin radiator and a couple spal fans. I would go bigger if possible. for big AN lines, look to the Nascar guys.
This was with a CSR remote pump
Old Jan 10, 2012 | 04:22 PM
westtexasbuff's Avatar
I'm using -20 AN on mine in black braided. You can find it on summit's website. http://www.summitracing.com/parts/EAR-350620ERL/ $113 for 6ft of it. Then you need fittings, and bungs.
Old Jan 10, 2012 | 04:45 PM
black98ws6ta's Avatar
20 an is prefered but I have used 16 on a few with no problems.
Old Jan 11, 2012 | 01:42 AM
minytrker's Avatar
Im going with -16 since thats the fittings I can get for my water pump setup. I can't see it being a problem on a track only car.
Old Jan 11, 2012 | 02:32 PM
koolrayz's Avatar
My new roller had -16 on it and that is what is going back on it
