Getting a little impatient .. My soon to be build
Tired of looking at this stuff just sitting here collecting dust, need my house to sell ASAP!!! Figured id share what all ive got going into my build. Heres the pics of the stuff.
As you can see I am living in a townhome and usually do work in my fathers garage BUT its full.
But rundown of what i have
lq4 shortblock (not pictured)
truck manifolds (not pictured)
317 Heads
Comp Turbo CT5 with a 80mm GT45 compressor wheel, triple ball bearing aluminum center section and a 79mm inconel turbine wheel. 1.15 AR divided ceramic coated turbine housing
Probe 4.00" 3.622" Stroke 2618 -16cc Forged Pistons
Eagle Forged 6.125" H-Beam Rods
Vic Jr manifold with rails
Low profile elbow
90MM wilson TB
78# Delphi Injectors
Aeromotive A1000 pump with filter and boost regulator
Comp Cam DUR @0.50 INT 226 EXH 236 Lobe SEP 114.0 Valve lift INT .584 EXH .601
ls2 timing chain
trickflow pushrods
ls7 lifters
patriot gold springs
Melling oil pump
Harland Sharp 1.7 rockers
50MM Tial BOV
Precision 46MM Wastegate
Snow stage 2 meth kit w/progressive controller
AEM wideband
AEM TruBoost controller
Unknown 3" inlet 4" thick intercooler
1998 Fuel tank to be sumped
Stuff on the way
Round truck coils
BMR Turbo K member
So thats my build so far, or i should say my build pile. The car is a 01 T/A that i traded my LS6 87 Stang for. It has a Strange 12 Bolt, tick stage 2 tranny, spohn suspension parts in rear. 3.73s..
Still need to order front coil overs and lower A arms for the car.
Everything seen here was thanks to LS1tech, everything was forsale on the site minus the gas tank. That was a local junkyard.
Let me know what i should add to my parts pile.
317 Heads
Low profile elbow
90MM wilson TB
ls2 timing chain
trickflow pushrods
ls7 lifters
Melling oil pump
50MM Tial BOV
AEM wideband
Stuff on the way
Round truck coils
BMR Turbo K member
