good valvespring for 18-20lbs of boost and a zr1 cam?
Old 01-19-2012, 09:08 PM
Moderator
denmah's Avatar
Default good valvespring for 18-20lbs of boost and a zr1 cam?
ive been using PRC's for alot of projects, but they are 300 bones, i have no complaints other than the price, i am sure i could be using something not so crazy. or am i doing it right?
ive seen lots of trickflow's iwth 130lbs of seat pressure and a set of comp duals for like 200 with 140lbs of seat pressure both rated around .600 lift.
a few of springs are out of stock like the comps and patriot's till the end of the month and i wanna start this project this weekend, so its leading me to wonder if some 120-140lb seat mild duals will be fine, and will they use stock retainers and cups?
what are you guys using and how much were they?
zr1 cam going in a stock 5.3 with a 70mm
Old 01-19-2012, 09:21 PM
Moderator
denmah's Avatar
something like this?
http://www.summitracing.com/parts/CCA-26925-16/
can i use stock retainers and seats and seals?
Old 01-19-2012, 09:22 PM
Moderator
denmah's Avatar
and here are singles with some good seat pressure
http://www.summitracing.com/parts/TFS-16120-16/
Old 01-19-2012, 10:12 PM
WS6HUMMER's Avatar
You get what you pay for, ask me how I know, lol.
Ran my best ET ever since then and still gonna go for 9's just like this, with Patriot dual Gold Extreme's. Btw they will be doing all of my machine work on my future build, great people & good workmanship.
Attached Thumbnails good valvespring for 18-20lbs of boost and a zr1 cam?-picture-001.jpg
Old 01-19-2012, 10:15 PM
Hank Peabody's Avatar
I used Pac 1218 on both my cars, were ok at 16psi on the Monza with the .561 lift cam, $140 at sdpc.
Old 01-19-2012, 10:20 PM
Moderator
denmah's Avatar
you've sold me mr hank.
damn i just got my zr1 cam and ls2 trailblazer cam gear from them, i could have thrown these on the order
Old 01-19-2012, 10:21 PM
WS6HUMMER's Avatar
Are those beehives or duals? I'm running a little 224/563 old school thunder cam & floated some beehives that were rated to 600" lift.
BTW, I had a 77 Monza (H07), was a bright yellow factory 305 car, I wish I never sold that thing!
Old 01-19-2012, 10:37 PM
Moderator
denmah's Avatar
ill be revving about 6200 max
what are you revving?
Old 01-19-2012, 10:59 PM
milkey57's Avatar
I run these good deal at 205 too :
http://www.coloradospeed.com/index.p...ducts_id=13960
Seat Pressure :153 lbs.
Open Height (in):1.150 in.
Open Pressure (lbs):400 lbs.
Old 01-19-2012, 11:04 PM
Those TFS springs you found look a little stronger, but the O.D. is bigger, makes me wonder if they fit in the head and can use stock retainers?! Is this for the Fairmont? There are going to be alot of junkyard turbo cars at Island this year!
The cam in my Monza/LQ4 is a 216/561, only revving 6000-6200, doesnt dyno for ****, Denmah dynoed it even(small world!) but ran 144-145mph at 3300# a few times so couldnt have been floating the valves, never stopped pulling. I seem to have better luck with the beehives than other people, or maybe the Pacs are just really magical
Probably good thing you sold that Monza, total nightmare finding a decent rear for them!
Old 01-19-2012, 11:05 PM
Moderator
denmah's Avatar
yeah i picked up a th400 and converter today! whoooooo here we go
Old 01-20-2012, 05:01 AM
Nitroused383's Avatar
If you're going to run a single beehive run the PAC 1518 or 1519 over the 1218's, not much difference in price and a lot higher quality spring. You really should be around 160-170lbs on the seat with that much boost, especially if your back pressure is going to be high.
WS6Hummer Was that the intake or exhaust valves that hit the piston? Intake valve if I'm looking at the pic correctly.
Thanks
Old 01-20-2012, 07:45 AM
LS1Tech Sponsor
hellbents10's Avatar
1518s
Old 01-20-2012, 08:32 AM
oange ss's Avatar
Lunati Dual spring kit is around $200, and comes with everything to install i.e. seals, retainers etc...
Old 01-20-2012, 11:20 AM
Louis's Avatar
That stock LS9 spring will hold 22 psi just fine in the ZR1s, but it does have a Ti valve.
WS6HUMMER's Avatar
Thanks
Yeah it was the intake valves, & can you believe that out of the 7 that kissed the pistons none were bent.
Old 01-20-2012, 11:33 AM
qqwqeqwrqwqtq's Avatar
...and there isn't 40+psi backpressure trying to hold the exhaust valve off it's seat
Old 01-22-2012, 10:13 PM
FOUROHSICKS's Avatar
I'm gonna use the ls9 springs from lingenfelter cheap too.
Old 01-23-2012, 12:34 AM
MattSapp95_T/A's Avatar
I am running Manley Nextek .700 springs w/titanium retainers.... cost a fortune but great springs!
Old 01-26-2012, 09:20 PM
lynmup's Avatar
Do you have any stock LS6 yellow springs?
Quick Reply: good valvespring for 18-20lbs of boost and a zr1 cam?
