Help choosing head gasket...
Old Jan 24, 2012 | 10:06 PM
jfg429's Avatar
Default Help choosing head gasket...
Im working on a 402 and want to get ready for boost... C.R is on the 10:5 range
what would be the best GM head gasket to go with my 317s to lower the comp a bit?? And how much bore head gasket can i go with for my 4'' bore block????? Thanks in advance
Old Jan 25, 2012 | 03:20 AM
Orange99Z's Avatar
Usually the best choice for being boosted is the LS9. Part # 12622033 I don't know how it affects compression though
Old Jan 25, 2012 | 03:49 PM
jfg429's Avatar
yes ive seen alot of LS9 users but my block having a 4'' bore can i use those being 4.100'' bore?? will it affect it in any way ?????? Thanks
Old Jan 25, 2012 | 04:46 PM
Orange99Z's Avatar
They work fine on mine with a 4" bore. Search a little, it's been said they can be used
https://ls1tech.com/forums/forced-in...adgaskets.html
https://ls1tech.com/forums/forced-in...ad-gasket.html
https://ls1tech.com/forums/forced-in...fo-inside.html
Old Jan 25, 2012 | 06:38 PM
jfg429's Avatar
Thanks!! Looks like ill be going with a set of those
