Turbo Firehawk build up V 3.0 AES 385 and S88
Old 06-09-2012, 06:44 PM
  #221
1fast bird's Avatar
Congrats Dan! Sorry I couldn't make it last night. Time to work on that sumped tank and get a BIG fuel pump.
Old 06-09-2012, 06:58 PM
  #222
98Camarod's Avatar
That's what I had to do. I got mine from behind bars race cars and went with a magnafuel 4303 pump.
Old 06-09-2012, 08:40 PM
  #223
crazy3rdgen's Avatar
Great footage, really liked the vid thanks! That backfire was mean!!
Old 06-10-2012, 05:51 AM
  #224
Fireball's Avatar
wow...what did you change to jump from 106-107 to 116 1/8 mph? was that just the jump in boost and you actually shifting when you were supposed to?
Old 06-10-2012, 10:07 AM
  #225
dschmittie1's Avatar
Yeah more boost and actually shifting around 6200 rpm and not at 5500. Or even shifting from 1st to 3rd
Old 06-10-2012, 02:03 PM
  #226
mike13's Avatar
If I'm not mistaken you did some street pulls to work on the tune and then took it to the track to dial in the tune?
At the track are you mostly looking for any KR and double checking your afr's?
Old 06-10-2012, 05:59 PM
  #227
Camaro9969's Avatar
Good work man car hauls!!! You said your running e85 on twins??? What injectors you using?
Old 06-10-2012, 09:05 PM
  #228
I did my driveablity tuning on the street and some WOT stuff. But on 12 psi it just blows the tires off in 3rd on the highway. So I only really was able to pull to 5200-5500 rpm on the street
Yes E85 on twin walboros and 127# FIC highZ injectors. I have a sumped tank sitting in the basement. I just need to get the pump and lines and modify the tank some then it is ready to go in.
It just sucks I need tires and all the fuel pump stuff. So it will be a while until I head back to the track as I just can't afford to spend that much on the car right now
Old 06-10-2012, 09:08 PM
  #229
Originally Posted by Cam72aro
Awesome video. Definately doesn't hook for crap. Its crazy that it ran as good as it did with that horrible 60. She definately pulls some mph.
Thanks I wish I could have ran that last pass out the back door to see what it would have run but I didn't want to risk hurting it.
Originally Posted by SKULL
Congrats on the passes. Nothing broke or blew up so I see it as being a successful night. Little more time tuning and running 18psi and it will see 8s with no problem. And maybe a little suspension tweaking and pull some mid 1.30s 60
Yeah I am sure I am just some suspension work and a fresh set of tires away
Originally Posted by THE1320
Saw you click off the 9.97 pass. Was wondering why you let out up top. Sounded pretty good coming down the track till that point.
Thanks car felt really strong and it felt great to be making passes in it again
Old 06-10-2012, 09:52 PM
  #230
mike13's Avatar
I'm in the same situation with the street tuning 390 W/billet 83/92 borg warner, I've been tuning but have to roll into the throttle in 3rd to about 80%. At the strip what rpm did you take the car upto?
Old 06-11-2012, 06:24 AM
  #231
Right now I was shifting around 6200 rpm. Once I get things straightened out probably 6600-6800
Old 06-11-2012, 07:36 AM
  #232
Just showed the video to some guys in at work and I just noticed it looks like I got on the brake before the traps as well. 9.97@129 on the brakes isn't bad at all
Old 06-11-2012, 09:22 AM
  #233
Camaro9969's Avatar
Im surprised the pumps are still holding up with that power haha they must be maxed out. Ya man i have found the same thing it just seriously never ends with this stuff. Then you will get that and need a different suspension set up or this or that. And there goes another 4000 bucks.
Old 06-11-2012, 09:28 AM
  #234
Really the only thing I could change in the suspension is go from my QA1s to AFCOs. Everything else is alraedy there. Last year the car never hit this hard off the line That and these tires are a year old and smooth in the middle.
Old 06-11-2012, 12:05 PM
  #235
moge11's Avatar
VERY AWESOME BUILD!!! I want to do a S475/s480 on my stock 346 while i build a forged LS3. gotta get this driveline strengthened up first though.....
....Cant wait to your car REALLY FLY!!
Old 06-11-2012, 12:36 PM
  #236
Cam72aro's Avatar
I bet you put tires on it and it will go. I understand on the money though, I am getting there right now with the little crap. Heat wrap, bends, lines, fittings, etc. It never ends. I bet when you get some tires you will be more than pleased with the results.
Old 06-12-2012, 08:47 AM
  #237
Camaro9969's Avatar
Ya some newer tires will help i'm sure. but it gets old after spending so much money. Not that a 9 second pass is bad i'd be very happy with that
Old 07-06-2012, 01:37 PM
  #238
Heading to do the dyno tomorrow morning for a little testing. Should be making some pulls on 14psi
Old 07-06-2012, 02:05 PM
  #239
2000RATA's Avatar
No shame in turning the boost up to say 20.
Old 07-06-2012, 02:10 PM
  #240
yes but right now I only have a 2 bar map and no good boost controller. So my 7psi base on the waste gate spring I can only double with a little manually controller
Quick Reply: Turbo Firehawk build up V 3.0 AES 385 and S88
