Huron Speed Single Truck Manifold Kit
#63
Thanks TJ!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
#65
The cross-over has a T4 flange and the down pipe is a 3" v-band. I don't see any issues with fitment as long as it is a T4. Most likely you will have to weld on a reducer to the Downpipe unless it is a 3" outlet and/or fab a larger down pipe. Shouldn't be a problem with fitment though and the whole cold side is good to go!
__________________
#66
Who else wants a nice kit at an awesome price?!?
__________________
#67
Do note: The pre-sale is almost up, soon these will be stocked and shipping daily!
Once the pre-sale is done, the price is going up, and eBay listings will either vanish or the starting bid will be higher. We are only selling at these low prices, at or below cost, now to get some kits out on the market to be seen! So if you want one at a low price, ACT NOW!
__________________
#69
Jon
__________________
#71
I will update you with tracking info via e-mail as soon as it ships!
__________________
#72
Three questions...
What alternator relocation kit will be needed to run this kit?
Does the kit have bracing for the turbo?
Do you know how much the price will go up after the pre sale?
Im very interested in this kit, but wont be able to purchase before the pre sale ends.
#73
Three questions...
Kit comes with an alternator relocation bracket
No turbo brace, certainly should not be needed when using a mid sized T4 coupled with the design and the 321 stainless
$2299.99
$2299.99
__________________
#75
Not a problem! Check out the kit we have on eBay for auction right now... going dirt cheap!
http://www.ebay.com/itm/260955952472...#ht_806wt_1291
__________________
#77
Possibly will in the future. Just need to figure out which turbo most will want to run and build around that. Like a PT88 and a 4" for example. In the mean time, we know the turbo will bolt up so everything will work for a turbo that may have a larger down pipe outlet, but you would just have to either modify the current down pipe to bolt up or fab up your own.
__________________
#79
Possibly in the future. The down pipe is going to be the most specific piece in the kit once you start venturing out past a mid frame sized T4 into the larger stuff depending on housing size to where the down pipe would start as well as v-band size and piping diameter.
If you are interested in a kit, shoot me a PM and we can work something out to where I can send it to you less the down pipe and you can have one tabbed for your specific goals!
__________________
