methonal injection, no intercooler
My idea is to keep using my alkycontrol dual nozzle kit its got a 10 and a 15 nozzle. i still can turn it up some more as well from my current setting. Ide like to use two 15 nozzles in the charge pipe, and was thinking about a 5 nozzle spraying in to the compressor inlet.
Now would the best spot for the dual nozzles be as close to the compressor out let as i can get? that would give the methonal more time to mix with the air.
What do you guys think?
The reason for asking if you are putting a lot of relience on the meth system and its pump.
Chris.
i could run e85 thoe, we have it all over here. all thoe the price isnt that much cheaper then 93. i could go the e85 route. not sure how much hp the magnafuel 4303 -10 an feed line and fic 103 lb (at 58psi) injectors will support on e85. i have my own hptuners so i could flash it for either fuel i decide to use
I did some street pulls the other night 2nd and 3rd gear on 8lbs after driving non stop for 30 min the highest IAT I saw was 113 with NO Meth and just my CRX racing intercooler and the Ambient temps were 90+
