Rods for 1k+ RWHP
Old Feb 3, 2012 | 01:52 PM
rat496boy's Avatar
Originally Posted by 98_LS1
Howards billet I-beams
Anyone else have feedback on these? The info online is all over on these.
Old Feb 3, 2012 | 02:14 PM
killernoodle's Avatar
Originally Posted by Bad News22
I just have a hard time associating anything Eagle with 1000+ hp
Stock powdered metal rods seem to be fine over 1000 hp at the flywheel (famous 4.8 hot rod article is my source lol) as long as you don't spin the **** out of them, so why wouldn't a forged rod be even better?
Most non-billet rod manufacturers use the same blanks for their rods from what I hear anyways.
Old Feb 3, 2012 | 02:34 PM
Bad News22's Avatar
So would this mean that all rods are created equal and a $500 set of rods will be just as good as a $2k set for a high horsepower build?
Old Feb 3, 2012 | 03:00 PM
Mr.Big's Avatar
Oliver or if you are big pimpin' Carillo
Old Feb 3, 2012 | 03:06 PM
corpserodeo666's Avatar
All I know is that for the price the Eagle rods have done me no wrong. My next block will for sure have Oliver billet rods. But when I built my motor those were the best I could get for the money and I have had 0 Issues with them. The only other reason why I would not run alluminum rods is because they tend to stretch after a certain amount of runs or strain on the motor. So take it for what its worth. Unless you are really trying to cut the weight down from your rotating assembly I would just stick to some nice 4340 Forged Steel rods.
Old Feb 3, 2012 | 05:32 PM
You'd be comparing eagle rods to someone else's billet rods? No comparison if we are talking about a zillion horsepower.
Comparing eagle to compstar to lunati to k1 with the same forged h beam design and same rod bolts is a waste of time though. I don't think it matters either way, especially at 1000hp where some engines have apparently survived with crappy PM rods. Just saying.
That $1500 extra you spend on billet rods isn't making you more power or really even giving you a more bullet proof motor because at 1000hp, forged rods are pretty much not the weak point. At 1500hp+, definitely get the fancy ones though.
Old Feb 3, 2012 | 09:19 PM
Bad News22's Avatar
Ok so I guess I should lay out the rest of my build so everyone can see the other components I will be running. First let me say that I am not someone with a unlimited budget that can just throw money at fancy components. I will spend $1500 on a set of rods if they are needed but for me that means that is $1500 to put into the rest of the car for supporting componests. The motor will be a 4.125 bore 4" stroke 427 with an RHS block. Crank and pistons will be Callies Dragonslayer and Wiseco pistons. Heads will be PRC Ls7 285cc with titanium intake and ss exhaust. So with that level of components in mind what rods sound like they are best? I guess I should also mention that is will be 1000rwhp so you can figure somewhere between 1200-1300 at the crank and it will be supercharged.
Old Feb 3, 2012 | 10:29 PM
texas94z's Avatar
Since we're on this topic, is there a known occurrence of a LS7 titanium rod failure?
Any 4340 I beam rod can withstand 1k.
Old Feb 3, 2012 | 10:32 PM
S4885.3's Avatar
If you have the money go with pauter x beams. they displace the power across the bearing surface better than H and I beams.
Old Feb 3, 2012 | 10:50 PM
koolrayz's Avatar
Im using the new callies ultra XD on my new engine build
Old Feb 3, 2012 | 11:31 PM
Fbodyjunkie06's Avatar
I think there are several X275 LS turbo motors going together right now with those Callies XD I beam rods. I think you will be fine with them without having to step to a billet piece. If you do go billet, BME, Olliver, Callies, Lunati, Carillo($$$) etc. are all good to choose from.
Old Feb 4, 2012 | 09:27 AM
  #32
bad6as's Avatar
Erik at hke built my engine. And he's built a lot of ls engines. When I said I wanted a solid 1000 wheel (1200 flywheel) he said my limiting factor will be the tune with pushing water. And he said it will take a good bit of power to lift the heads with the arp studs, tfs heads and ls9 gaskets. He used callies compstars in mine.
Old Feb 4, 2012 | 09:44 AM
  #33
HydroStream6's Avatar
I'm on Scat forged I beam rods... right at 1k hp and no issues so far.
Old Feb 4, 2012 | 09:55 AM
  #34
zipster's Avatar
I fix forklifts for a living, I had a call at this place http://www.rrconnectingrods.com/stee...teel-rods.html
The shop is amazing, they gave me tour of the place I could not believe their quality. I have no idea how much anything is, but after talking to Mike he explained the differences in steel quality, treating, and the machining. Just an unbelievable amount of knowledge. Its almost a shame to put the rods in an engine and never be able to show anyone what they do.
Old Feb 4, 2012 | 11:09 AM
  #35
88GT&69ss's Avatar
Originally Posted by Old Geezer
Was really impressed with our little eagle rotating assembly. In our mustang on our dyno it made 1150 to wheels- 347 and single turbo. and we ran 5.0's in the 1/8th all day long. we would lift heads time to time, but never had a issue with the bottom end.
Old Feb 4, 2012 | 11:22 AM
  #36
Ryne @ CMS's Avatar
LS1TECH Sponsor
made 850 rwhp in a supercharged application, without failure
Old Feb 4, 2012 | 11:36 AM
  #37
delphigto's Avatar
Billet lunati or oliver would be my choice.
Old Feb 4, 2012 | 11:45 AM
  #38
S1LV3R's Avatar
After reading through here it seems the I beam rods are stronger? I always thought the H beam rods were supposed to be stronger?
Old Feb 4, 2012 | 01:21 PM
  #39
SnIpEz's Avatar
Nope
Old Feb 4, 2012 | 08:02 PM
  #40
Bad News22's Avatar
Decisions decisions.... Part of me wants to just go with a Eagle rods and save some money but part of me feels like at this level I should step up to a Lunati or Callies rod.
