Rods for 1k+ RWHP
#41
I think the only rod Lunati makes for the lsx platform is the billet ones. Pretty sure they no longer offer the non billet pro mods.
I had an issue with my last motor that pretty much made me decide it's a bad place to skimp. Not saying that I know for sure that it was a rod failure, but it opened my eyes to what the wrong ones will do. See for yourself......https://ls1tech.com/forums/forced-in...nevermind.html
#42
So this whole rotating assembly rating system is driving me crazy. I called Callies again today to spec out a complete rotating assembly to see what they say and I yet again got a different answer. When I told them I needed an rotating assembly for a LS 427 build for around 1200-1300 crank hp they said I would need to less than a Magnum crank & Ultra I-Beam rods. Apparently the Compstar crank is rated to no more than 800hp and Compstar rods are now 900hp. I never thought picking out a rotating assembly would be so difficult lol. I was getting ready to pull the trigger on the Compstar stuff but now I am a bit leery.
#43
They are covering their ***. To be fair, they have no idea how much you will be spinning the motor to make that kind of power. 1200-1300hp is alot easier on parts if you only spin it to 6500 rpms vs. the same power at 8500 rpms. For that reason they are rating them at a "safe" power level. There are companies that won't even give a power rating for that reason. Just too many variables.
Get yourself a Callies Dragonslayer and do the Callies HD I beams. If you want more piece of mind get billet rods from either Oliver, Lunati or the Callies ultra billet. Any of the above mentioned will work great.
#44
Any of the American made "racing" rods will hold that, probably the better chinese stuff will too. With what your block costs though, I would pony up for some of the big names.
Most rod horsepower rating comes from RPM though. A cup motor or a max effort NA small block drag motor spinning 10,000 rpm to make 900 to 1100 hp is exponentially harder on connecting rods than your FI motor making 1200 at 7500 rpm. It is the tensile strength that the HP rating comes from, not the compression strength.
Why do you think the SPS rod bolt option is so expensive on Carillos? That is the rods week point, the cap. Also, where is the thinnest point or least material on a con rod? The little end above the wrist pin, compression loads do not effect these areas at all. Start spinning that thing and get that piston speed up, that is when these rods break. Super high compression loads may bend them, especially detonation, but RPM is what really puts the hurt on them. So you may want to ask your favorite rod manufacturer how they come up with the rating. You may get one of the engineers to admit that yes this rod is fine at 1200 HP as long as the RPM doesn't exceed 7500-8000 rpm.
#51
LS1Tech Sponsor
I agree that RPM is a factor and also intended usage. A dyno queen/street car can get away with a lot of inferior parts at big power levels. This is different then some one who races every weekend with good tires under their car. A race car that bangs the turbo and makes 20psi on the hit and carries 30 down the track is tuff on parts.
I have seen Eagle stuff survive just fine running high 7s. Then again I have seen some break too!
At an honest 1200+hp I would go for a oliver rod as they are very affordable. After 1800 if steel is the choice Dyers is the hot ticket.
#52
if proline says a rod will handle 1200, then call me a believer, and in their 1200hp capable ls package, they use callies compstar rods
http://www.prolineracing.net/engines...tfs-235-1200hp
oliver billet rods in the 1500,2000 and 2800 hp packages
#55
#57
I have a set of Oliver rods I no longer need. My engine builder used Manley rods instead. Will let them go for $800 plus shipping. PM me if interested.
I think they are 9.27 pin, 6.125, 2.100
#59
yes there been a few of those inexpensive rods blow up in a motor.
A few of them bend up under very high HP too.
but most people with the cheaper stuff really dont push them really hard.
A few times at 1000hp for a dyno pulls then driving on street is a cake walk.
