bad ass 4x4 build. opinions wanted
Pretty much I believe. I tapped a the whole and put a fitting in where the old one was and ran a line to the new map because it wouldn't just snap into place. Had it tuned for the new 2barmap and all was good.
9 Second Truck Club
Ok when you guys say a 220 cam are you referring to the lift or the duration? Because technically I need to know both. I know on my talon I ran 272 duration on the intake and exhaust but no one ever talked about the lift.
I also have been lurking trying to find what I need to do to setup the truck for a tune. More than likely I will be using a 2007 engine, harness, and ECU along with EFI live. From what I have gathered after 2005 they stopped using the hot wire gmMAF....? If thats the case then they are only using manifold pressure....? HELP! What do I need to convert to turbo from NA?
