Turbo on my 422
I am considering going with a turbo set up on my forged 422 ci and before I make the call to place the order I just wanted to see your guys thoughts. I was thinking of going with LS1 motorsports for their turbo system. Should I go with the T-76 upgrade do to the large displacement of the motor? My comp. ratio is are 10:1. Also should I change my cam, I am using the S1 cam from MTI. I dont want to go super crazy as far as PSI but pretty much as much as I can run safely on the street/strip. What kind of number do you think I could get at the wheels?Thanks
Chris
first, if it was me, I'd go with a diff cam. I went with something like the LPE GT2-3, but with more lift. I think your cam has too much duration, but that's just my opinion
second, I would imagine with a good tune, you could safely run 10 to 12 lbs on your CR. I wouldn't be surprised if you hit high 600s/low 700s on proper fuel with that much boost.
I went with a 408 Iron block, I'm running the turbotech T-76. My goal is 18 psi on 8.6:1 CR
I'm sure others with more experience will chime in soon...good luck with everything!
That cam will have too much overlap.
Try bbrannen@compcams.com and see what he says, but I would keep in mind that most cam companies will suggest cams that are comparably smaller than supercharger cams so if it sounds milder it is.
I've seen you state this before. Harlan has said the same in different threads. The small frame PT88 is rated at 1,200fwhp vs. the PT76 GTS, which is rated at 1,100fwhp. That doesn't seem like much of a difference. In real world application, the PT76GTS was good for 980rwhp on a pretty "tame" combo'd Supra (recent mag article). I've also been told that the GTS has laid down more than 1,000 rwhp on another application. Now you maybe (probably are) right about your assessment. Can you explain to me why a 422ci LS1 would have problems making at least 650-700rwhp at 12psi given the right supporting hardware? Thanks in advance for entertaining the question. This is turning out to be a great thread.
I'm not trying to say that it WON'T work, but if I were in your shoes I would run something that would give me more flexibility in the future. If you decide that you want to make more power you pretty much have to reengineer the entire kit and try to fit a TV-frame turbo in there, or rebuild it alltogether.
A gt42 or a 76 gts support 1200 hp. I think that will provide a lot of growth for an ls1 car.
Earl H will show some people what kind of hp a 76 gts will support .
Like I said, this just just coming from personal experience, I don't really have any scientific evidence to back myself up, but to me it makes sense. It's like running a single T3 exhaust housing on a V8, sure 4banger hondas can make 500+ WHP with a single T3 with fair backpressure levels, but would you want that dinky housing taking the exhaust gas from a 500 RWHP LS1? I think it would be come quite a restriction, even at the same power levels as a honda.
The t3 exaust housing on a 500 hp 4 cyl and a 500 hp ls1 will see the same backpressure since it still takes the same amount of air and fuel to make 500 hp.
