Race port springs
I just recently got my turbo project running and my 50mm turbosmart race port bov is open at idle. I am guessing it needs a stiffer spring in it. It already has the 18 inHG spring in it but with my ls6 cam i have about 20-22 inHg on vacuum.
So i see that it is possible to get an inner spring to add 3-4 inHg to the outer spring rating, which would probably be perfect. The only question is where can i get one. All the places i find seem to be in Australia. Also i have the previous model, so do the new springs fit the old model bov?
Thanks in advance,
Tyler
Thanks in advance,
Tyler
ok so iv continued searching and search and searching.............................
What iv found is that the turbosmart website says that the 4inHg spring comes in the race port spring kit part number TS-0204-2104. Well thats fine and dandy except that the only places that carry that part number are overseas and want an arm and a leg to ship a $20 spring kit.
Iv also found that many places in the US carry a race port spring kit with a part number TS-0204-2004. Thats also great except that everyone who carries that has absolutely terrible descriptions of what it contains/ and or conflicting descriptions between dealers. I am assuming its the same kit i listed first, but dont want to buy it with out knowing for sure.
I hate stupid problems....
It is the way they are. Even if you put a harder spring in it to avoid it being open at idle, it'll be open the first time you decellerate. If you are worried about it being open to the atmosphere, maybe an atmospherical BOV isn't right for you.
When the throttle body blade is shut, the BOV has to open......Otherwise where is the excess air supposed to go. That is the purpose of a BOV. At idle the throttle body is closed-----therefore-----the BOV should be open.
If it is opening when you are under power....and the throttle is open......then you have a problem.
BOV- open or closed:
Typically the Raceport is used on vehicles using speed density, and it is closed at idle.
It can also be used on mass air flow cars and in this application, you would most likely want it open.
It all depends on your particular setup and how your tuner has tuned the vehicle to run.
Let me say that I do not advise using the Raceport setup to be open at idle. The reason is that it is drawing in un-filtered air.
On these applications, I recommend using our Plumb-Back valve with the outlet either plumber back into the air box or with a small K&N filter installed on it.
This valve has plenty of flow and is quite popular on both turbo and supercharged applications.
