Lean spike as I enter PE (and knock retard) any way to combat this?
Formerly 4mulaJoe
Where did you get this information about the BE table? This is the first I have heard of it. Tuning your afr based off the map makes much more sense than tps and/or rpm on a turbo car imo. I never had any issues on a centrifugal set at 759rwhp.
My own personal findings and there is info posted about it on the hptuners forums. I have lots showing cars being well into boost yet the boost enrichment fueling isn't active it has a delay even when setting the map kpa low. It's best to setup your desired afr with the pe table.
i have never touched my transient fueling at all. There is still some more work you can do before you have to commit to that.personally i still believe your problem could lie within your injector data. have you tried entering smaller amounts in the VE table instead of just throwing 20% at it? try increments of 2 or 3 and slowly work from there to see if it improves. real time tuning would make this very quick.
