4.8 stock block build
Shooting for decent numbers here. Got.an 05 4.8 one of the heads is.junk so I have. Set.of 317.heads was thinking maybe cut them a little to.get.to.9 to 1 I have Arp head studs and permatorque mls gaskets, motor will be fed by a tc76 turbo truck manifold setup, and a custom ground boost cam a 60e 3500 stall and some other.**** truck is a gutted 95 s10 awd what.do.you guys think about the 317 heads I wanna boost 17 to 20 when its all done what kind.of power numbers have you guys seen? Its all stock unless.I stated otherwise. I will have meth injection and.80# injectors tho
Not too many turbo 4.8 builds that I've seen so I couldn't tell ya what it may make for power. If you can get it to hold together at 17-20 PSI, then it would probably make around 600 to possibly 650 RWHP. But 20 psi is a lot of boost I would think, even with meth. I'm shooting for 600 RWHP with my LS6 cammed, ARP studded 5.3 with a 76mm. Stock 317's on it as well which should give it right about 8.6:1. If that gives you any idea of what you may possibly make.
Mine is a stock 5.3. I made 588 to the wheels blowing through the convertor. However, I run E85. With pump gas and meth it is probably equal to the E85. My tuner thinks it is probably closer to 635 to the wheels. I run 15lbs of boost. The 5.3 and 4.8 are similiar.
talked to my machinist today heres the plan
-port+polish stock 862 heads
-cut seats and install stock 317 intake valves
-install a set of patriot dual springs w/ titanium retainers
-custom grind 224 cam
-double roller timing chain
-ARP headstuds
-oem 05+ 4.8l mls headgaskets
-stock bottom end
-truck manifolds w/ v bands welded on
-TC76 turbo
-Aeromotive A1000
-80# siemens deka's
-Aeromotive a1000 FPR
- -8an feed line
- -6an return line
-Edelbrock victor jr ls1 intake
-low profile elbow
-95mm throttlebody
-3500 stall convertor
we came to the agreement this should safely make 650+ wheel hp on a good tune with meth. what do you guys think i mean the guys on Horsepower made 1200 with twins lol so it should at least be able to get 7
-ARP headstuds
-stock bottom end
-TC76 turbo
-Aeromotive A1000
-80# siemens deka's
- -8an feed line
- -6an return line
-low profile elbow
-95mm throttlebody
-ARP headstuds
-stock bottom end
-TC76 turbo
-Aeromotive A1000
-80# siemens deka's
- -8an feed line
- -6an return line
-low profile elbow
-95mm throttlebody
-ARP headstuds
-stock bottom end
-TC76 turbo
-Aeromotive A1000
-80# siemens deka's
- -8an feed line
- -6an return line
-low profile elbow
-95mm throttlebody
