LQ4 S480 Build
Old Jan 8, 2013 | 07:29 PM
  #321
F110Mech's Avatar
Roto joints wouldn't be as bad. I'm doing roto joints on the rear side and poly on the body side. Best combo for a street car IMO
Old Jan 8, 2013 | 08:11 PM
  #322
fastsspr's Avatar
Man i want to seea video of your car at the track.
Old Jan 8, 2013 | 09:09 PM
  #323
Camaro9969's Avatar
Originally Posted by Sarg
I will be running the Truetrac eventually, but it is all solid rear end bushings and such.
I am actually going to try out the Fragola push lock braided nylon stuff. It is pretty reasonable and looks to be good quality from everything I have read.
Ya i have a couple of those push lock things i liked them a lot but decided to swap all my lines so i never kept them on the car.
Ya its the Torque arm i believe thats the most annoying of the group. That paired with the spool is just a brutal combo! I'm kind of stuck with this arm now though so i'll either have to sell it and buy one with poly bushings or suck it up! LOL
Haha You and me both
Old Jan 8, 2013 | 10:22 PM
  #324
F110Mech's Avatar
I saw you on HPtuners forum, How do you disable all TM on the engine side?
If its a threaded in rod end then u should be able to get a replacement poly end from umi to change it over.
Old Jan 9, 2013 | 05:19 AM
  #325
Camaro9969's Avatar
Its a Spohn I sure hope your right I would be pumped. I just emailed him to ask. Thanks for the heads up on it.
Old Jan 10, 2013 | 04:26 PM
  #326
Camaro9969's Avatar
You were right i can swap the rod ends out for poly or even the del spheres just not sure how those would be on the street anythings better than this garbage i have now
Old Jan 15, 2013 | 04:38 PM
  #327
Camaro9969's Avatar
Took the car out last night for a drive it was awesome! Beat a V10 M5 on the way just toying with it.....Cant ever get full throttle even at 105 started spinning the tires on the highway. Amazing for 8.5 deg timing and barely hitting 7.25psi LOL One thing that already needs to get changed are the gears, Currently have 373s and was almost topping them out. Thinking of 325's or maybe 342's just want something that isnt so annoying on the highway.
Sorry they aren't that clear
Old Jan 15, 2013 | 06:16 PM
  #328
F110Mech's Avatar
Car looks awesome, You should bring it down when mine is done so that we can race
Old Jan 15, 2013 | 07:21 PM
  #329
Camaro9969's Avatar
Thanks man!! Definitely that would be awesome.
Old Jan 16, 2013 | 07:38 AM
  #330
douglee25's Avatar
Crazy!
Old Jan 16, 2013 | 08:16 AM
  #331
Sales@Tick's Avatar
Do you have a 12 bolt or a 9"?
Old Jan 16, 2013 | 10:19 AM
  #332
Camaro9969's Avatar
Moser 12 spool I believe the 12s only can get 342s or 308s?
Old Jan 22, 2013 | 09:20 AM
  #333
Camaro9969's Avatar
Got a quote to change the gears for 375. Think i'm just going to go with the 342's. Id rather a nicer gear for the highway but i really do not want a car that cant 60'
Old Jan 22, 2013 | 05:06 PM
  #334
MUSTANGBRKR02's Avatar
Trust me put a 2.75 gear and 8lbs of boost and that car will 60' no problem.
Old Jan 22, 2013 | 06:56 PM
  #335
Sales@Tick's Avatar
Even though it might help it 60' some a bbc x275 nitrous car cant even pull that kind of gear and a 3.08 is pretty damn steep too, but more doable. I'd personal do the 3.42 and get a good boost controller. If it was a race car that weighed 3200lbs. or less I'd put a glide or turbo glide in it with a 3.73-4.30 rear gear depending on first gear ratio, but it's not a race car unfortunately lol.
Old Jan 22, 2013 | 07:40 PM
  #336
Camaro9969's Avatar
The 342s will suck for the highway and probably top out right towards the end of the track which is good.....but 308s would be better for racing bikes on the highway. ill try gear and if I hate it ill have to swap again. Its cheaper than a built 4l80 haha
Old Jan 22, 2013 | 07:59 PM
  #337
F110Mech's Avatar
I still would go with 3.08s but you're right, my 4l80 will cost 10 gear swaps lol
Old Jan 22, 2013 | 08:54 PM
  #338
Sales@Tick's Avatar
I had 3.55s in my old turbo car and used to murder bikes on the highway, but do what you think is best. By the time you pull 5 cars on a bike they usually let off anyways. With 3.55s on 11psi I crossed the 1/4 mile at 6300rpm. This is also with a 26 inch tire not a 28 inch tire. More boost would of meant more rpm at the traps from converter slippage, but my converter was pretty tight anyways. Just giving first hand experience, your converter must be looser than mine.
Old Jan 22, 2013 | 10:09 PM
  #339
78buturbo's Avatar
im in for the 3.55 unless you put that beast on a diet, let it rev and put those bikes on the pass side LOL
Old Jan 23, 2013 | 12:20 PM
  #340
Camaro9969's Avatar
I'm going to buy both sets and learn how to do it will be much easier than spending 750 bucks
Hahahaha thats the damn truth!
What converter do you have? Once i run mine at the track i'll know how it reacts a little better.
Haha Good idea!
