LQ4 S480 Build
Old Jan 23, 2013 | 02:49 PM
  #341
Sales@Tick's Avatar
It was a 10" FTI 3800rpm rated stall converter.
Old Jan 31, 2013 | 02:35 PM
  #342
Camaro9969's Avatar
Took the car out and did a little tuning today got the idle very close to where i want it and a quick fly by video. I need some damn traction! couldnt even get on it more than 21% according to HP Tuners before it started spinning lol
Old Jan 31, 2013 | 06:53 PM
  #343
Sarg's Avatar
really gives me hope for my build. I can't WAIT to get it started and on the road!
Old Jan 31, 2013 | 07:04 PM
  #344
78buturbo's Avatar
sounding good all we need is some nice warm days!
Old Jan 31, 2013 | 08:57 PM
  #345
mrfood's Avatar
Were those fast fuel rails tough to modify and have you heard anything about the holley rails? Which injectors did you use? Are you planning some dyno pulls? very professional build man
Old Jan 31, 2013 | 09:18 PM
  #346
Camaro9969's Avatar
I haven't heard anything about them I really like the fast rails but I actually had to go through two sets before i got the right ones. The set that fits on the ls6 intake are one number and The other ones that some people get are specific for FAST intakes only. I can give you the one for the LS6 intake if you would like or even take a picture of the fuel rail on the car.
I used the 80lb siemens injectors that are very common with these turbo builds. I have the FP at 58psi so they are actually 95.5's right now
I will do some dyno once i get the tune perfect just trying to get some nice pulls with it but weather stops me from doing that.............Thanks for the comments!
Ya no kidding i was pumped for the 60 deg day we had but now back down to 29 haha oh well i guess i can wait
Oh Trust me you will love it! So addicting!!!!!!!!!!!
Old Feb 1, 2013 | 06:37 AM
  #347
rspeed's Avatar
Nice work.Did you get the idle problems sorted out? I have the same injectors and can't get mine to idle better than 11.9 to 12.2. If so what did you do?
Old Feb 1, 2013 | 07:54 AM
  #348
Camaro9969's Avatar
Yes i had some help from another member on here but it took me a good 6+ hours of adjusting to get them to idle where i wanted now idles 14.2-14.7 Still have some surging after beating on it but i'll take care of that next.
You gotta get the correct injector data first and there is a whole list of things to do after that. If you have the data for them start working on the ve to lean it out. Hp Tuners? Speed Density? A little info on what you have done would help.
Old Feb 1, 2013 | 08:40 AM
  #349
rspeed's Avatar
Hp tuners sd2 bar . Car runs good rear mount s475 ls1 but at idle it drives me crazy .iv been trying to lean it out with the ve table but It just doesn't seem to get any better than 12.2 .
Old Feb 1, 2013 | 10:09 AM
  #350
Camaro9969's Avatar
Did you get the right injector data? What fuel pressure? I really don't know what you have adjusted. There's a bunch of things you need to adjust so it can even start going lean. Short pulse adder min pulse volts vs rpm etc ...
Old Feb 1, 2013 | 05:03 PM
  #351
Camaro9969's Avatar
Ditched the rod ends and found these for 100 with the the adjustment tool.
It should be against the law to run rod ends with a spool it was so awful!!!!!!! Think ill get rid of the rod end on my torque arm next
Old Feb 1, 2013 | 06:03 PM
  #352
MUSTANGBRKR02's Avatar
a Anti roll bar would help the rod end noise greatly.
Old Feb 1, 2013 | 10:16 PM
  #353
Camaro9969's Avatar
I have a Wolfe but its not hooked up I heard they were even more annoying lol. It would help with the noise??
Old Feb 5, 2013 | 09:44 PM
  #354
mrstepheneades's Avatar
Is the car very loud driving it. I'm running in my downpipe out the fender is well. Sounds wicked...
Old Feb 6, 2013 | 03:29 AM
  #355
Yes it would help. I have all rod end suspension inthe rear and it was horrible until I added the ARB and that eliminated all of it.
Old Feb 6, 2013 | 06:41 AM
  #356
Camaro9969's Avatar
Thanks!!
Its actually not too bad under or above 22-2500 just right in that range its annoying. Like droney if you know what I mean.
Old Feb 6, 2013 | 07:47 AM
  #357
Yeah i know what ya mean. Ive had some exhaust setups in pass out the rear that were like that. I will also have a pretty big cam in mine. Its just a ls1 though for now. Should be running in a few months.
Old Feb 6, 2013 | 08:28 AM
  #358
Camaro9969's Avatar
Ya my exhaust set up last year was more obnoxious I had long tubes with a borla and the plates. It was basically open headers haha
But now its only loud if your on the passenger side. Its kind of funny from drivers or the rear you barely can hear it. Not used to that. Maybe a bullhorn would help lol
Old Feb 6, 2013 | 10:53 AM
  #359
yeah i had longtubes, 3in xpipe, and dynomax bullets lol..... if you consider those mufflers...
Old Feb 6, 2013 | 01:35 PM
  #360
Camaro9969's Avatar
haha ya this wont be too bad then. Plus the sound of the Turbo you couldn't care less on how loud it is
