LQ4 S480 Build
Old Jul 20, 2013 | 10:08 PM
  #681
Sales@Tick's Avatar
Awesome Doug! I'm glad the settings I had you start with are working so well.
From what I can see in the video, the front end is rotating at a perfect rate and is transferring weight at just the right amount of speed. The tight compression setting is also allowing the nose of the car to stay up throughout the run keeping weight transferred on the rear tires.
I can't see what the rear is doing, so try and get someone to video tape that like I mentioned to make sure when you really start getting after it that you aren't hitting the tire too hard. With how I had you set the rears up, they should be fine unless you change rear gears or until you get to 18-20psi of launch boost.
With the rear gears you have, you will probably end up launching at 18-20psi to really get this thing moving.
Old Jul 21, 2013 | 05:03 AM
  #682
Camaro9969's Avatar
Wow I can't wait to try that!! :-) thanks again!
I didn't expect it to hook so well and these tires barely need a burnout which is nice. When I'm at the track friday ill give you a call and let you know. I do like the gear for the street but at the track im going through the traps at like 5800 lol
Next time out ill try launching with where my boost is at (16) and see how it does. I'm also going to work on my tune off the transbrake so it lights the turbo up way faster. Ill add some timing and lean it out should help things a lot down low. The less time on my transbrake the better!
Old Jul 21, 2013 | 12:43 PM
  #683
Mystery Bird's Avatar
Congrats Doug!
Old Jul 21, 2013 | 08:40 PM
  #684
Sales@Tick's Avatar
Get 34-36 degrees in it initially on the trans brake. Don't be scared of it. Once you get some boost lit, pull it down to 22-24 by 5psi. Then have all of your timing out by 7-8psi as in where you run the timing advance down track.
Lean it out to 13.2-13.5 on the trans brake, and have fuel slowly taper in to 12.2-12.4 by 5psi. By 7-8psi you want your air fuel to be what it will be going down the track. Normally on pump fuel at your power level I shoot for 11.0-11.4.
This is the way I tuned Old Gold's car and a few others I've helped with. Works very well and makes the car very responsive.
Turn it up to 16psi on the leave the next time and don't mess with the shock settings at all. I bet you see a 1.38-1.40 60' on 16psi leave.
You just need to turn the power up so that you're at a higher RPM when you go through the traps. Until you get above 12-14% slip in the 1/4 I wouldn't worry about the converter.
Old Jul 21, 2013 | 10:27 PM
  #685
mrstepheneades's Avatar
Tell him he don't need that 2 step Martin that way I can get it lol.....
Old Jul 22, 2013 | 04:14 PM
  #686
Sales@Tick's Avatar
Sorry Stephen, he really needs a two step! If he doesn't put one on it, it may end up running away with the converter one day if he stays on the trans brake too long.
Old Jul 25, 2013 | 01:58 PM
  #687
Camaro9969's Avatar
Well dialing it in will be put on hold.
took it for a cruise didn't even get on it and spun a rod bearing. didn't expect that at all but pretty bummed. How the hell that it happened on the street and not beating the hell out of it at the track is beyond me. 1500 miles street driving 21 passes most with more boost also. But its a really annoying part to go. I will have the oil sent out I think instead of fixing this one ill just pick up another and swap my cam heads oil pump and timing chain over. Got a big chunk done already and will have it pulled saturday. Just still surprised since I had the slp oil pump clevelite bearings and arp rod bolts but guess it happens that way....
I guess on a positive note ill have the engine bay sprayed and get rid of my heater core while its out
Old Jul 25, 2013 | 02:16 PM
  #688
Rise of the Phoenix's Avatar
So sorry to hear that. Your car is what's inspiring me to do a turbo LQ4 build. I hope you can get it back in good running order without much headache.
Old Jul 25, 2013 | 02:37 PM
  #689
Camaro9969's Avatar
Thanks man I appreciate that. It shouldn't be too bad if I grab another motor, just a lot of swapping parts over I'm trying to stay motivated.
Old Jul 25, 2013 | 02:55 PM
  #690
How much do you expect to pay for another LQ4? Just tying to figure out what the going rate for a junkyard one is.
Old Jul 25, 2013 | 03:08 PM
  #691
Camaro9969's Avatar
They range all over. I found a few for 500 some 750-1000 bucks depending on the year
Old Jul 25, 2013 | 03:14 PM
  #692
You looking at the typical places like junkyards, CL, etc.? Are the ones you're seeing in the 500 to 700 dollar range coming with wiring harness and CPU?
Old Jul 25, 2013 | 03:25 PM
  #693
Aw man that stinks. Get it back together in time to run Musclepalooza with me Sept. 1st.
Old Jul 25, 2013 | 03:53 PM
  #694
Blackpanther99's Avatar
Damn, sucks to hear that bro. Check on your local yunkyards or CL.
Old Jul 25, 2013 | 04:11 PM
  #695
Hate that Doug. Its the game we play!
Old Jul 25, 2013 | 05:21 PM
  #696
douglee25's Avatar
Good luck. I know you'll have it together soon!
Doug
Old Jul 25, 2013 | 08:33 PM
  #697
MUSTANGBRKR02's Avatar
Order some pistons, rods and either a pan or improved racing baffle.
How much oil are you running in it and what brand?
Old Jul 25, 2013 | 08:34 PM
  #698
I know of a forged shortblock 370....
Old Jul 25, 2013 | 08:45 PM
  #699
Forge it Doug. Then 20+ psi
Old Jul 25, 2013 | 10:07 PM
  #700
Camaro9969's Avatar
Ya i actually have a spare but it has a ton of miles and is an older one with the other style rods. I found one near that is an 03 with 102k for 600 bucks but no wiring i do not need any of that but the ones in the 1000 range do come complete
Ya man its a bummer but i'll hopefully have it back together soon
I will def be there with ya Sept 1st though!
Doug
Thanks I appreciate it i'm hoping to have it running by next weekend just depends when i can get all the parts in. I'll need new gaskets and studs this time around just to be safe.
Thats a good idea on the improved baffling i will look into that.
I'm running the rotella t6 but that will be the last time i ever run it. I'm sure thats not the cause but thats just how i am. One issue and im out! Im going with AMS oil next
Oh trust me i've thought of it! I would gladly take a ride down to NC to pick that up this weekend and tow your car back with me
Ya i knew i would be getting those comments lol
Only issue man is forged motors do not prevent a rod bearing issue. I was hoping to get 20-24 psi out of the stock motor and not sure what actually happened. I'll have the old motor torn down sat so i'll find out what can be repaired.
