LQ4 S480 Build
Just stab that bad boy in there as is with the fasteners and LS9 gaskets and let it eat. When it breaks get another 300 dollar motor and go again. Doesnt matter if a motor's forged or stock they all eventually meet the same fate when you are dealing with these power levels. Just keep the boost to a consevative 15-16 psi on the street and put it on kill at the track and it should last awhile.
I honestly wouldn't use the ARP bolts. You're not turning enough RPM to need them IMO and I've never seen a bolt break or come apart. Just bent rods.
I think your clearances were too tight. What were they?
I'm also going to smarten up and add meth this time around I should of in the first placeI honestly wouldn't use the ARP bolts. You're not turning enough RPM to need them IMO and I've never seen a bolt break or come apart. Just bent rods.
lolBut while I run the stock bottom I'm going to build a forged motor for the next round. hopefully I can make this last till the end of the season......
Also finishing up another Lstech members kit hopefully by next week or so ill post some pics of that
