how much power and boost???
Old Mar 21, 2004 | 09:54 AM
Parker TX's Avatar
Default how much power and boost???
hey guys i am new to the board and am looking for answers from veterans on forced induction. i have just built my lt4 383 from the ground up. the internals are eagle forged crank and h-beam rods and JE 8.1 dished pistons. AFR hydra-rev kit, New AFR 210 heads that flow about 300, 1.6 rockers, port matched intake, 58mm throttle body, 232/248 @ 113, procharger D1-SC with asp cogs pullied to 15#, and a griffin intercooler like Pro Stock Johns. sumped tank with a -10 feed and -6 return to MSD 50# injectors. this is going to the ground through a fidanza flywheel, Spec stage 3 clutch, carbon fiber drive shaft and moser 12 bolt with 3.55.
how much power will this set up make and how much boost is safe? Any comments/suggestions on this setup are appreciated.
Old Mar 21, 2004 | 11:47 AM
stealth's Avatar
Dyno it and find out.
Old Mar 21, 2004 | 11:55 AM
1dirtyZ's Avatar
what is this thing you call "lt4" ??
Old Mar 21, 2004 | 03:49 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Your LT1/LT4 combo sounds super stout, if you make about 15psi on that low compression I am thinking you might be close to 700rwhp, for sure well over 600rwhp.
Old Mar 21, 2004 | 09:35 PM
Parker TX's Avatar
i am about two weeks from finishing the entire setup, ill post dyno #s soon, and Pro Stock John, nice intercooler set up, gotta luv it.
Old Mar 22, 2004 | 01:09 PM
LS1Tech Co-Founder
Yah keep us posted... and thanks for the props on the FMIC.
Old Mar 22, 2004 | 02:01 PM
Crunch's Avatar
I agree with Pro Stock John. A chevy 383 stroker with 12 lbs of boost, good heads & cam, should be around 600RWHP with a good tune. I would say 15 lbs should take you to the mid 600's, maybe closer to 700 with race gas.
Old Mar 22, 2004 | 11:04 PM
Parker TX's Avatar
i have a few more ?s, what oil should i run with this set up, i had planned to put 114-116 octane in it and just run open loop on the tune. Also i would like opinions on who or which shop is the best at tuning f.i. lt1/lt4 cars, as of right now im looking at SpeedWorks in Lewisville. any input is great, thanks.
one more thing, where is everyone mounting there BOVs because i just bought a turbonetics godzilla BOV and want to know the best place to mount it.
Old Mar 23, 2004 | 11:12 AM
LS1Tech Co-Founder
I am running Redline synthetic.
I have been dynoing with VP C12, which is basically 110 leaded.
I have a FAST system.
My Vortech Mondo Bypass is mounted on my FMIC on the inlet side.
Old Mar 23, 2004 | 01:30 PM
1dirtyZ's Avatar
psj, does the valve on your BOV slide up and down on the shaft it's mounted on?
sorry for going off tangent .
Old Mar 23, 2004 | 01:37 PM
LS1Tech Co-Founder
I do not know.
Old Mar 24, 2004 | 08:16 AM
Parker TX's Avatar
im mounting the d1sc today, woohoo. with my new cog pulleys thanks to this board, the fmic will be mounted this weekeng thanks to this board. i will post pics tonight if anyone is interested. one more thing psj what weight are you running.
