obx vband clamps any good?
Old 02-23-2012, 01:30 PM
killernoodle's Avatar
Originally Posted by ACCLR8N
If you are doing that, wouldn't running a 2.5" flange over your 2.25" 16ga tubing be easier?
Depends what the outside diameter is. I have found that most of the scrap stainless 3" I have laying around my shop is actually slightly larger than 3" in diameter and almost never fits perfectly in the vbands without a little work. This would be much easier with an exhaust pipe shrinker and expander set.
Ideally, you would get 2.5" OD exhaust pipe that fits snugly in a 2.5" vband, though you could probably use 2.25" and use an exhaust pipe expander to expand it to 2.5".
Old 02-23-2012, 02:39 PM
GulfM3's Avatar
Originally Posted by killernoodle
No need, just assemble your pipes like this:
Great Idea!
Old 02-23-2012, 02:41 PM
blackonblacksls's Avatar
Order all your Vbands from racepart solutions. Best ones I have used. And I have tried all the obx an non name brand ****. And I kick myself in the nuts every time.
Old 02-24-2012, 11:03 AM
Valkyn's Avatar
Anyone ever used these flanges?
http://www.ebay.com/itm/3-5-Turbo-V-...item3a64843d96
They are the type that slips onto the pipe, dont look quite as beefy as the OBX tho.
Old 02-24-2012, 02:54 PM
Those look just like some of the ones I've bought before. I don't see any problems with them.
Old 02-24-2012, 02:57 PM
Originally Posted by LS1NOVA
The v bands I was using before had a step on them to locate the pipe and you couldnt push the pipe through. I definately like that though, looks like it would be much stronger.
I just realized what you meant when you said it has a step to locate them. that kind of tube joint won't work for the method I posted, and need the male/female locating rings.
I'm talking about the kind where you can slide the pipe through the vband.
Old 02-24-2012, 08:24 PM
cloviskillaxx's Avatar
dont overtighten obx clamps or the lil spot welds snap.
Quick Reply: obx vband clamps any good?
