HOlley Hp Efi and Boost with Stock Coils... Problems?
Sounds like a poor design by Holley... I'd like to hear an actual, legit, engineering explanation of what's going on that's frying the ECMs. Of course, that's not going to happen, they're not going air out their dirty laundry.
I may have left something out, but thats what he said. Guys name was Tom. Im going to run it the way it is, just keep things low i guess i can spend the extra cash, im more worried about actually getting the car running at the moment, then ill deal with the BS that is the ignition issues.
I can actually understand it being harder for the spark to jump... if my understanding is correct, under high pressure there's a lot of air and fuel molecules that the electrons physically have to push their way through to jump. But back-feeding into the ecm is a lack of protection circuitry.
This is the one? http://www.holley.com/550-603.asp
Here are the facts..
There have been some issues with both the HP and Dominators on some applications use factory LSx coils. This is far from a black and white condition. Depends on cylinder pressure, which has many variables, plug wires, and the different coils among other things. The issue appears to be due to very short, high voltage spikes that these coils produce, back on the coil trigger, which should be a clean 5v signal. There also appears to be an RF noise component as well, which is very complicated.
I've personally run 30 PSI on an engine with GM coils, with no issues, and have seen issues at 14 PSI. As mentioned, there are variables.
We should be testing some different hardware, in the next couple of weeks and will know more in a while.
People are advised to run the Holley coils right now if they are making a lot of cylinder pressure. We ran another COP type of coil on a couple of cars this weekend, making 2000+ HP without any issues, but would like to review those coils more before I comment futher.
People with specific questions should contact Holley. I'll post more shortly when we know more.
LS1Tech Sponsor
That was 11 years ago. Those guys are elsewhere because they didn't have a clue.
I know Robin, Doug and Rick they all know what they are doing. Doug helped me in BG this year with the issue I was having with my cam sensor. Rick has answered a bunch of little ? I had prior to getting my systems. Robin I have known for 9-10 years from racing mustangs.
Belive me they all what this stuff to work perfect everytime and do work hard every day at it.
If you belive the other EFI systems don't have issues you are kidding yourself. They all have issues from time to time.
Alot of times issues are caused by people not following the directions on install
The systems works well I went 10.00 on the first pass with this LSX combo and a very very consertive tune just to get down the race track. 3rd pas 9.82 came home and tested 2 more times within 11 passes 9.66. No dyno time and 10 miles of driving 2 6000 rpm pulls in second gear is all the tuning that was done.
Tim
Tim
Guys,
Hold up here, lets not get crazy, I firmly believe the HP/dominator are top of the line, or i wouldnt have make sacrifices in my build to have it.
Tim, as i posted on Bullet, my seller, was under the impression all issues were fixed, even on the first page, the guy with the RX7 thought the issues were fixed on the new units.
Whether or not they were told they were, or lead to believe they were, or thought they heard things were better, doesnt change the facts.
The website should say their are issues before people buy into a product with the impression that it will do something that its advertised to do. Im not pissed, it is what it is.
Im working with someone at holley right now. Im not going to comment on anything further until we come to an agreement.
I can tell you this, i believe Holley to be good people, personally, i feel like they want this system to be top notch. I cannot blame them, with the name they have to uphold and the name they market.
We will see what happens, i will no matter what use this system. Tim, it was because of the things you posted in the electronics/ecm section on this site that helped me to make my decision.
I will not change my opinion of the guy from their tech department that basically told me to get over it. But the other people i have been talking to are top notch.
#32
LS1Tech Sponsor
#34
This is the key. Holley should be up front about the issues. Of course, all their competitors likely have similar issues and aren't up front about them either
#38
Restricted User
One other thing, even with the Holley Coils no other other system on the market even comes close to the bang for the buck that this system provides out of the box.
True Auto Tuning alone makes it worth it without all the I/O data logging capabilities and integrated controllers.
#39
Also, to add to this alittle more, the coil kit comes with a nice set of written instructions on what changes to make in the OS to run them based on the LS reluctor wheel.
