how is boost limited on a whipple?
so school me my brain doesnt get it. on any roots style blower how is the boost limited? i dont get it a turbo has a waste gate so that at Xpsi it opes and limits boost. now my gpt for example has a bypass so it will not boost but how does it know to only build 5 psi or whatever? cause it has 5 psi at lets just say 3000 rpm so in my head since it spins faster at 5000 rpm something has to keep it from makin more boost? if the bypass has some sort of pressure spring to open and allow only 5 psi then how the hell does a pulley swap work cause whatever kept it at 5pis with a 3.5 pulley should keep it at 5 with a 3.0 pulley....................
thanks for some real knewb lol questions lately
The only thing limiting it to X psi with the first pulleys, was the RPM of the blower...
Change the pulleys and spin it faster.... then you get more boost.
The only exception to that is using a wastegate on the cold side, and a boost controller just like a turbo system does on the hot side....
Some people do that too
check out this graph of a whipple 3700 rpm 8.9 psi 5700 rpm 9.1 psi
http://pdfcast.org/pdf/whipple-sc-dyno-results
im less concerned about pulley swap as i am how psi is limited
As you spin the positive displacement blowers faster they lose efficiency because the fill time is getting fast and volume is reduced at the rotor, so eventually you will see boost fall off slowly as speed increases with blowers like your 3.8 GM engine. That type of blower is very good at low rpm.
Kurt
In modern superchargers they come built in with the bypass valves but are mainly used to eliminate backpressure of the supercharger during low load conditions. However they can also protect against compressor surge also. Let's say you want a maximum of 10PSI and if you see a surge to 11PSI you want that pressure vented. You could do that for the most part however don't even think that you could truly control beyond that.
But keep in mind there's not much flexibility to a supercharger when it comes to truly controlling boost levels. In a turbocharged application you can electronically set your boost levels on the fly. I can set mine from 10PSI-25PSI without making any other mechanical changes. It does this by adjusting the amount of exhaust gasses striking the turbine and thus spinning it at a rate that matches the requested boost level. A supercharger bypass valve can limit maximum boost but isn't designed to control it up or down on the fly as dictated by an electronic controller.
At the end of the day on a Turbo car you can be at 3000RPM and be pushing 25PSI then be at 8000RPM and can push 25PSI also. Hit a button on the dash and change it to 10PSI and it'll adjust on the fly. Can't do that with the Supercharger. It's strictly boost levels at a certain spin rate of the compressor lobes which is tied to a fixed ratio based on engine RPM.
So unless someone has invented a constantly variable pulley system you're outta luck in truly controlling boost.
was overcomplicating the whipple setup for some reason. As you spin the positive displacement blowers faster they lose efficiency because the fill time is getting fast and volume is reduced at the rotor, so eventually you will see boost fall off slowly as speed increases with blowers like your 3.8 GM engine. That type of blower is very good at low rpm.
Kurt
dead on!
bbammmmm ther ya go man as soon as i read it i shook my head lol im retarded thanks for layin that out
