Been Busy
Everything went ok but had a little trouble with the sway bar not wanting to fit between the rear shock mounts. But Mike came up with a way to make it fit and it works and looks great. Installed the supercharger and had the same problem the others had with the belt not fitting correct due to it being to short. So we took the steel bracket back off and elongated the slot for the tensioner. Reinstalled it all and now the belt goes on by hand with the tensioner on top of the belt. Didn't get to drive the car due to needing the driveshaft shortened because of the gearvenders od unit. But should get to take it for a spin tomorrow afternoon and then off to APE on Wed. for tuning. So it looks like we will soon see if all the hard work and $$$$$$$$$$ has been worth it. Tom
Tom
Thanks.....
Tom
This could be the answer, now I just need to get those pins in the mail, take the crank bolt out w/the COG crank pulley, put the new pins in, and locate a 250ftlb TQ wrench and a flywheel holder......
Thanks
J
Tom, How was getting those 60#ers to idle and run?? I should be getting mine this week and i will have a base tune in there to get my car running to put 1000 miles or so on it before i dyno tune..... was it hard and did you have to change alot of stuff?? Thanks
Kyle
maybe thats why i coulndt get ahold of anybody, i tried to call some of you guys last week and ask advice on getting my engine out, but no answers from anybody. got it out though with some elbo grease, all by myself.
Are you going to set up your car tune for race gas or pump?
hopefully youll have a good year at the track, cant wait to see it around.
Tom
I know what ya mean about the JET........
I wish I could take some vids of my car......there is one floating around on this site in the multimedia and midwest forums of the SPEED INC. open house vid, my car is the opening car in the vid....
Keep us updated TOM, and let me know if you have any skipping teeth problems.....
and yes that sucker is loud. As least bos can keep the streets of Elk Grove Clean with his full race street sweeper
Tom
I will be heading up with Tom on Weds to APE for the tuning. Will bring the video camera for sure
