Oil returns on turbo setups.
Old Mar 21, 2004 | 08:32 PM
MYTURBOT/A's Avatar
Default Oil returns on turbo setups.
I want to reroute the oil return on my car so it works alittle better. Is anyone running the return to the oil drain plug? If so how is it working for you? What about taping into the driver side of the oil pan about about a inch or two down from the top lip? Thanks.
Old Mar 22, 2004 | 07:29 AM
Tiago's Avatar
drain plug should be out of the question. BAD idea. On the side is ok as long as its still above the oil level in teh pan.
Old Mar 22, 2004 | 08:22 AM
MIGHTYMOUSE's Avatar
i agree, and mine is on the side.
Old Mar 22, 2004 | 08:25 AM
smokinHawk's Avatar
id like to improve my drain as well
since i have the engien out now, i will go with a bigger drain, like a -10AN with all AN fittings and braided line.for no leaks
Old Mar 22, 2004 | 08:37 AM
MYTURBOT/A's Avatar
Anyone know how far the oil level is, up the side of the pan? Sounds like a nice idea maybe i`ll look into doing somthing similar. Mighty do you have any pics of your return?
Old Mar 22, 2004 | 11:01 AM
i can take some.. keep on my back about it
someone on here once filled up a pan for me to see how far the level went up to decide where to put the hole..
i ended up getting nervous about hitting rotating parts and put it in the driver front corner.. but when i sent the car to george he switched to the side and used -10 also
Old Mar 22, 2004 | 02:45 PM
02BlueFirehawk's Avatar
mmmm, so you're saying the front bottom driverside corner isn't where it should be?
Old Mar 22, 2004 | 02:56 PM
MYTURBOT/A's Avatar
The front corner is where it`s supose to be but we're trying to find somwhere that will allow it to drain better.
Old Mar 22, 2004 | 03:22 PM
ok, I was getting worried. :-p
Old Mar 22, 2004 | 04:31 PM
02blue i guess it depends on who you ask
heres mine.
Old Mar 22, 2004 | 04:45 PM
MYTURBOT/A's Avatar
Looks good MM, How much lower do you think that is then the TTi street kit and QMP mounting location?
Old Mar 22, 2004 | 04:50 PM
dude its freezing outside, ask all of your qestions at once! lol.
i would say the hose itself ends at about the same height maybe a half inch lower at most.... but here the oil just turns and falls into the pan, where as in the front location it has to go straight vertical to get back in.
Old Mar 22, 2004 | 11:27 PM
2FAST4U's Avatar
mine is as the Incon instructions say front center of oil pan. I had a alum. -10AN fitting welded before it got powder coated. But now with the belt driven scavage pump the lines are going to be tight!
Oh and b/c I had it welded on with the pan off the fitting is no where near the inside of the pan, so no worrys on it hitting something!
Old Mar 23, 2004 | 06:05 AM
smokinHawk's Avatar
ill try to bolt the turbo up to my engine with it out and see if MM's location would work with the TTi street kit. and get pics.
I think that the oil line being straight as it comes off the turbo then to the pan, then must travel up (due to the fitting) causes it to smoke.
Dave you have the tubular Kmember, do you think the stock Kmember would get in the way if we were to route the line like yours?
Old Mar 23, 2004 | 07:12 AM
not at all.
Old Mar 23, 2004 | 08:07 AM
MYTURBOT/A's Avatar
I think a setup like that would also stop the tendency for the oil to slosh up and back up the drain under hard breaking. Thanks for taking the pics MM.
Old Mar 25, 2004 | 06:40 AM
smokinHawk's Avatar
i took alot of pics last night with my log and turbo bolted to my engine (as its out of the car now)
it shows were a good place to place the drain would be and such.
but dang it i forgot to bring them to work so i could post them!!!
ill get them up tomorrow.
im definatly going to go with the 10an steel braded line draining into the side of the oil pan.
Old Mar 25, 2004 | 06:42 AM
smokinHawk's Avatar
Mightmouse how far is your drain from the bottom of the oil man.
can you measure it for us.
Old Mar 25, 2004 | 07:26 AM
ok .
Old Mar 26, 2004 | 06:40 AM
smokinHawk's Avatar
Pics are up
http://www.cofba.org/users/smokinhaw.../oilreturn.htm
as you can see it looks like the side will work and not have to travle up the connector to drain.
