Meth vs Nitrous
Old Feb 29, 2012 | 01:52 PM
moehorsepower's Avatar
Default Meth vs Nitrous
I know there is a debate going on about how much timing on meth, But on another subject, Who has run nitrous as a meth cooler and how was it? I am contemplating on nitrous. I believe it would be simpler, more of a cooling effect, Of course you will have to tune to it, What I mean by simpler is that I hear too much on the mixture of meth. I hear from 100%, to 50 / 50 to 20% ect...
Pros and cons of both?
Old Mar 1, 2012 | 02:34 PM
mconway68w's Avatar
One makes you laugh, the other makes you speed and your teeth fall out... Sorry man. I'm actually curious as well.
Old Mar 1, 2012 | 03:01 PM
I know one makes you laugh, I already have nitrous plumbed into the drivers seat with a pilots mask for me, I'm talking about spraying it into the motor
Old Mar 1, 2012 | 05:04 PM
NemeSS's Avatar
From an economy standpoint. Meth is cheaper.and more readily available.and provides a source of fuel as well.
Old Mar 1, 2012 | 05:28 PM
02gangsta/ss's Avatar
when you run meth you set it up and tune it to run 100% meth ...no water !!
Old Mar 2, 2012 | 07:33 AM
chuntington101's Avatar
I hate to say this but please have a search of these boards for info. There is a mountain of threads of meth injection, water / meth injection and using N2O. Do a search and find the info.
Chris.
Old Mar 2, 2012 | 01:36 PM
Chris.
Well don't say it then, I did do a search on meth vs nitrous and vice versa with no results, Why chime in just to give a negative comment. I just don't understand people like you...
Old Mar 2, 2012 | 02:35 PM
Johnv's Avatar
For outright performance, nitrous.....
but only really suitable/practical for a track orientated car.
it will put more demand on your fuel system {unless you have a stand alone fuel setup}
and won't add knock/det protection from added octane like meth will.
It will supercool inlet air temps and is a great power adder when setup correctly,
Meth is a more suitable option for a street car,
It will cool intake air temps and add knock/det protection, there would be a modest gain in power without any other changes just from the cooler air charge, and it will allow more boost and more timing to be supported for those that want to push there setup.
Old Mar 2, 2012 | 11:01 PM
Fbodyjunkie06's Avatar
Good post.
Old Mar 3, 2012 | 07:55 AM
Thanks, Good post as F said. Yea I'm not looking for any more power, just the safety factor and I only run at the track when I go the the Ltx shootout.
Now I just need to decide which meth controller, I believe they are all pretty much the same and basically the mixture, I need to study up on that.Thanks again for the informative post....
Old Mar 3, 2012 | 11:34 AM
Martin718's Avatar
No in fact they are NOT in fact all the same, mixing alcohol in the wrong pump will destroy the pump causing catastrophic failure if your tuneup if using methanol in it's fueling table. And on that note please DO NOT mix meth with water!! For simplest reasons your "mixture" will never be consistent. Secondly the benefit of 100% methanol far succeeds the benefit of a mixture.
Put it this way a drum of 55 gallons of methanol is 180$ just about anywhere you are. I travel across the U.S. And still manage to find it, and I know a lot of fuel supply company even deliver. As far as kits go stay away from junk like snow performance ect.... The pumps are cheap and fail!
Get with Julio at Alky controls (813)265-1400. He will hook you up with anything you could ever need for a kit and is always there to help.
Old Mar 5, 2012 | 06:40 AM
Thanks, Good to know about the kits, Yea on the mixture I was talking about,is what you are saying, because I heard about a 50 /50 mix with water, straight meth ect. I will give Julio a call. Thanks again.
Old Mar 5, 2012 | 08:26 AM
goinfast's Avatar
Alky control is the best!
