Using PE Adder vs. IAT as safe guard for meth failure?
Anyone both pulling timing and increasing fueling based on IAT's?
I know this. I guess if I run a progressive meth controller with a smaller nozzlw it would prob help.
Plenty of people use meth the way it was meant to be used and have no problems. I send my pump out once a year to ensure that it is operating at 100%. that is what is recommended by the manufacturer.
Saying that, we still run many cars with it and some tuned heavilly on it. We have had no problems with the kits we use- alky control but have seen many failures by a few other kits, those I will not tune for.
So, tuning IAT can help IF the intake heat gets hot enough.
That was the exact problem we were having with my car. Not running much boost only 12lb at 6600 air temps are so low already. I also dont have a progressive controller so we had to pull a lot of fuel. I'm building a forged ls2 and maxing the d1 out. So I'm pretty comfortable driving with a meth relied tune for a few months. Im pretty much use to watching my wideband from my bottle setup.
There is no idiot proof racecar. The best is to keep tabs on everything that is part of teh fuel system. The LS computer allows for this type of safeguard. But doesnt allow for someone racing on an empty gas tank.
Cost of C16 is 95 for a 5 gallon pail. Pump rebuild is 80. Do the math. The math goes against you when you wait "years...." to do what should have been on your spring cleaning worksheet.
