How much should this make?
Old Mar 22, 2004 | 02:10 PM
PurEvl's Avatar
Default How much should this make?
PP ls6 72cc 6.0l stage 2 heads
230/234 .598/.602 on 114
lsx intake
forged ls6 3.905 bore with -2cc reliefs
8 psi ati D1 8 rib
42# injectors
ls1 speed fuel rails
true dual x pipe with hooker headers
Old Mar 22, 2004 | 03:02 PM
BIGBOS's Avatar
@8psi I would say 525-550rwhp, what trans?
Old Mar 22, 2004 | 03:09 PM
PurEvl's Avatar
6 speed, Heads,cam,intake just did 420 rwhp with no tuning other then air/fuel
Old Mar 22, 2004 | 03:16 PM
BIGBOS's Avatar
You could probably see 550rwhp with a good tune.....
Clint who has a COG setup w/10-11psi made about 625rwhp through his 6-speed with a boost bleeder cam and a built 348c.i. motor........
Old Mar 22, 2004 | 03:46 PM
PurEvl's Avatar
thanks for the info man
Old Mar 22, 2004 | 04:34 PM
NA$TY-TA's Avatar
lsx intake
8 psi ati D1 8 rib
42# injectors
Why would you waste your money on the LSX intake when the cash you are wanting to spend on it can buy you a set of forged rods........ The rod bolts on stock rods are the weak link...
Why only -2cc valve relief pistons..... if your going to buy pistons why not get a set of -8.66cc dish pistons so compression is at 9:1 with those heads..... be more boost and pump gas friendly and you can run more then 8psi with that combo.....
What head gaskets???
Are you using head studs??? good time to upgrade....
what fuel pump to support this???
Other then that looks good man......
Thats just my .02
Kyle
Old Mar 22, 2004 | 05:24 PM
PurEvl's Avatar
WHOA! calm down
the motor was already built and had an NA setup before. The lsx was laying around so why not, beside it cost me 600...chump change. Yes there are head bolts on there. I figure my combo cant be anymore then 9:4 so its not that bad. I have the arp rod bolts and the entire setup is blue printed and balanced as well.
Old Mar 22, 2004 | 05:50 PM
MIGHTYMOUSE's Avatar
was laying around???
if i could get an lsx intake for 600.. i'd put it on ebay.
my guess is 580 on race gas.
Old Mar 22, 2004 | 11:27 PM
NA$TY-TA's Avatar
WHOA! calm down
Didnt know that man. When ya posted you should of said that....... I didnt want ya to spend all that $$$ and then go ........
Kyle
Old Mar 23, 2004 | 08:17 AM
Noyzee's Avatar
8 second mod
id say about 23 rear wheel.
jk, with that set up i would guess about the same, 550 or so
Old Mar 23, 2004 | 09:30 AM
PurEvl's Avatar
my luck it will put down 450
Old Mar 23, 2004 | 11:44 AM
Slowhawk's Avatar
LS1Tech Sponsor
550+ Easilly on pump gas
Here is a graph of a 98,stock block/heads, 224/230 cam and P1 blower pushing 6lbs A D1 with 8lbs and ported heads/bigger cam=more power
Old Mar 23, 2004 | 11:59 AM
Noyzee's Avatar
8 second mod
yhea, i think 550 is a good goal pump gas, if it makes more, it just feels that much better.
Old Mar 23, 2004 | 12:14 PM
Noyzee's Avatar
8 second mod
5, any idea on what the heads flow? what are the specs on them?
just wondering.
Old Mar 23, 2004 | 12:31 PM
PurEvl's Avatar
just wondering.
304 @ .600 PP stage 2 ls6 6.0l 72cc chamber cnc'd
Old Mar 23, 2004 | 01:20 PM
squirrel masta's Avatar
From: its as intense as the time i forgot how to sit down
it takes a good driver to put down the power,where are you gunna find one
ooooooooooohhhhhhhh.....SNAP!!!!!!!! watcha gunna do
Old Mar 23, 2004 | 01:49 PM
PurEvl's Avatar
put your mom in the back, should get some traction...SNAP.... Im Mike James bitch
Old Mar 23, 2004 | 03:04 PM
98BLKMOBILE's Avatar
Quote: "Here is a graph of a 98,stock block/heads, 224/230 cam and P1 blower pushing 6lbs"
Hmmmm... that graph looks very familiar I wonder what it will look like 3 days from now.....
Brian
