Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
Old 04-21-2012, 11:32 AM
  #181
Moderator
denmah's Avatar
took it to the track last night, fuel filter clogged up a little on the way to franks thursday night, and on the dyno i had to keep adding fuel, so it was clogging up again, from the damn foam in the fuel cell, so first place we stopped halfway to numedia i pulled over and ripped the foam out i had to clean the filter 3x more on the way up and at the track, then after 2 passes they said my tranny was leaking, wich it seemed to be but very minimal, must be the tail shaft seal *new* or coming out the overflow... *overfilled?*
anyway had to clean it again before i left, and it didnt bother us the whole way back down, nearly 2 hour drive.
i didnt get any good ET passes, because the brakes on this car are way worse than the other car, i couldnt hold it still for **** at the line to try and build her up, so i got 2x 2.3 60fts in a row, car still went 99 in the 8th and 127 in the 1/4, picking up 28mph out the back door i am pretty happy with that!
gunna rebuild these front brakes, they drag like a mother farker, and feel like im stepping on a stick of butter, least it stopped at the track twice lol.
anyway pretty happy with 2.0 it cruises better and feels more solid than 1.0
gotta get the brakes sorted and see what i can do, otherwise ill be piping this thing with an extra nitrous kit i have like 100 out of the hole and turning it off in 2nd and 3rd gear, just so she can 60ft hard, so i dont have to get a retarded converter ill hate the rest of the time i am driving
Old 04-21-2012, 02:50 PM
  #182
jleews6's Avatar
Good mph and 28mph on the second half is rolling. How much boost were you running to go 127?
Also,If you have a local junk yard with any late model Mustangs in it the 87 and up front brakes on the 5.0L cars are bigger and they are a huge improvement over the brakes you have now. Go with some good pads when you do it and you should like them.
Old 04-21-2012, 11:07 PM
  #183
Moderator
denmah's Avatar
14lbs of boost goes 128.80 on a 2.0 60ft lol
127.00 on a 2.3 60ft...
i might just buy new calipers and good pads off the internet, for the car but i bled them out today and they are way better,
Old 04-21-2012, 11:13 PM
  #184
jleews6's Avatar
128.8 on 14 pounds is crazy for such a mild combo. I cant wait to see it run at 20 pounds.
Good pads will make a big difference but keep the 11" brakes in mind. You can find them cheap and they are a big improvement.
Old 04-21-2012, 11:26 PM
  #185
Moderator
denmah's Avatar
drove these two around a bunch today, replaced the front upper suspension bushings in the ventura, drives so much nicer, installed a harbor freight boost gauge that has been sitting in the box in the car for a long time.
then we bled the front brakes on the fairmont, changed the oil, undercoated it and installed a class 3 hitch from a E250 van corey had laying around lol.
gunna tow a trailer full of **** down to OCMD, and also so i can tow my slicks and jack and toolbox etc when i go racing, it also helps it look even more sleeper and adds weight to the back end for traction lol.
some pics of the ventura painted with bed liner.
hands of a turbo car owner.
and a 80s photo of an autozone.
Old 04-21-2012, 11:37 PM
  #186
Moderator
denmah's Avatar
http://www.youtube.com/watch?v=HRwBNnsqSxE
Old 04-22-2012, 08:22 AM
  #187
a4ls2goat's Avatar
Keep up the good work. Car is defenitily a sleeper!
Old 04-22-2012, 01:50 PM
  #188
6point7s14's Avatar
Sweet ride man
Old 04-22-2012, 09:57 PM
  #189
Moderator
denmah's Avatar
Old 04-22-2012, 10:16 PM
  #190
831jd's Avatar
Are you still running stock head bolts?
Old 04-22-2012, 10:49 PM
  #191
Moderator
denmah's Avatar
ARP bolts
Old 04-23-2012, 01:39 AM
  #192
a4ls2goat's Avatar
Now its getting interesting.
How much are you gona spray?
Old 04-23-2012, 06:59 AM
  #193
Moderator
denmah's Avatar
gunna try 75 to make her 60ft
Old 04-23-2012, 08:38 AM
  #194
2nd Gen Fl 'bird's Avatar
ARP bolts
Ok, I get the studs vs stock head bolts thing but, is there any advantage other than ARP head bolts being reusable? Less bolt stretch for better clamping maybe? They are better priced for a budget build I guess.
  #195
a4ls2goat's Avatar
Are you gona dyno it to see the difference? I bet it'll make close to 100 more whp with a 75shot.
Old 04-23-2012, 09:30 AM
  #196
atomic 6's Avatar
The real question is did you put aftermarket axles in this one, or c-clip eliminators???
Old 04-23-2012, 04:07 PM
  #197
oneoverwrx's Avatar
Do you do any clean up/ porting to the compressor housing? I made the inlet of mine have a smooth transistion where it starts to reduce. I also made the compressor outlet 2-3/4, I took it back about 2-1/2" from the edge of the outlet. Not sure how much of a difference this will make but figured it couldnt hurt.
Also, what size oil feed do u have on yours?
  #198
Moderator
denmah's Avatar
Yes loser hardened axles
Old 04-23-2012, 04:08 PM
  #199
Moderator
denmah's Avatar
Loser = moser. Lol autocorrect
Old 04-23-2012, 06:25 PM
  #200
79-mailbu's Avatar
what junkyard has $80 engines im in PA willing to travel
Quick Reply: Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
