Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
Old 01-20-2014, 10:29 AM
  #2201
OldGold's Avatar
Originally Posted by HRHohio
What plugs are you running on this setup?
Congratulations on your progress. Outstanding... And "Conservative and alive" is a good thing. More time racing... less time wrenching.
BR7EF. I had two sets of 8's, but they are non-resistor and Microsquirt really does not like non-resistor plugs. However, I know that if I want to turn it up, I am going to need to run a colder plug.
Mike
Old 01-20-2014, 10:31 AM
  #2202
HRHohio's Avatar
Ahhh. Thanks for the info. Congrats again!
Old 01-20-2014, 10:41 AM
  #2203
ls1_chevelle's Avatar
Originally Posted by OldGold
The last time I hit it with 15* I melted a plug and bent a valve 900 feet out and coasted to a 9.3 after a 5.9 in the 1/8. The car will run 8's as it sits on 18 psi. Once the intake and springs are swapped, I think it will make more power without the need for much more timing. I prefer to sneak up on this. I am in no rush.
Mike
Weird. I ran 16 degrees 50/50 91 and 112 on 9psi on the front half and 17psi on the back half, spun to 7000 and its alive. Lots of different ways to make power.
Like I said its obviously working well. I do like the wider window you have with less timing and after hurting an engine from timing... I don't blame you for the approach lol.
Old 01-20-2014, 01:11 PM
  #2204
OldGold's Avatar
Not saying it was definitely a timing issue. But, timing makes me nervous. I popped a ring land on a 5.3 in this car on 13 psi, 15* timing and Prestone wiper fluid. While I was at the dyno this weekend, my friend lifted a head on his Vette on 17 psi and 17* of timing and pump.
Mike
Old 01-20-2014, 01:44 PM
  #2205
Moderator
denmah's Avatar
17/17 stranger danger
Old 01-20-2014, 03:44 PM
  #2206
Sales@Tick's Avatar
Slowly getting there.
I will put in some fresh plugs next time for Martin, LOL.
Mike
A man after my own heart!
Old 01-20-2014, 06:17 PM
  #2207
jleews6's Avatar
Originally Posted by Martin@Tick
Because until Mike can put fresh plugs in it and read them after a pull the timing will stay at 13-14*.
It's making dumb power for 18psi the way it sits right now, really no need to cram timing down its throat.
I'd rather turn up the boost and leave the timing low. Timing is what wrecks engines. I like managing the cylinder pressure the engine is making by running low timing and running a lot of boost.
It took us a while but 20 years ago we learned this with the turbo Buicks. Keep the timing conservative and keep cranking the horse power ****.
Old 01-21-2014, 08:36 AM
  #2208
Moderator
denmah's Avatar
whoa whoa! sounds like you have been going to sloppy school!
drinking my coolaid lol
what i always do when a car makes power that easily, or seemingly easily, i pull 1-2 deg out, and see if it makes the same power while i am on the dyno, then i know if i was a little over center to begin with.
just a suggestion, i also like to read the strap
Old 01-21-2014, 09:52 AM
  #2209
OldGold's Avatar
That is a good idea, Matt.
Old 01-21-2014, 05:07 PM
  #2210
Sales@Tick's Avatar
Oh believe you me, when he pulls those fresh plugs out with one dyno pull on them, and the timing mark is where I think it is on straight 116, it's getting enough timing to make even a sloppy sensai cringe.
Old 01-21-2014, 06:11 PM
  #2211
I-H8-RICE's Avatar
I need to stay off this forum untill i get my garage done, cars like these make me want to say screw it and start my car instead! lol Awesome build, nice to see it stay alive on the forum after the sale.
Old 01-21-2014, 07:05 PM
  #2212
Moderator
denmah's Avatar
Old 01-22-2014, 06:41 PM
  #2213
Joye227's Avatar
What size hotside were you running before you changed to the 2.25 hotside?
Old 01-23-2014, 01:40 AM
  #2214
Moderator
denmah's Avatar
a 2.5 disaster that i built
Old 01-23-2014, 12:32 PM
  #2215
Joye227's Avatar
Is this car controlled by Microsquirt?
Old 01-23-2014, 12:35 PM
  #2216
kainedogg's Avatar
I assume so, since it has a seperate controller for the trans.
Old 01-23-2014, 12:36 PM
  #2217
Joye227's Avatar
Never mind. Just saw that answer to that question.
Old 01-23-2014, 12:37 PM
  #2218
Moderator
denmah's Avatar
yes its running microsquirt and an optishift trans controller
Old 01-24-2014, 06:13 AM
  #2219
kjm
kjm's Avatar
Nice job on the car Mike, anytime you ready to add that anti roll bar. Let me know. And I'm sure with that new found power a cage upgrade will be needed soon lol. I will be home from Brazil Saturday. I'll hit u up.
Kerry
Old 01-24-2014, 11:24 AM
  #2220
OldGold's Avatar
Kerry
Let me know when you are back in town.
Mike
Quick Reply: Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
